Should there is a notch in the first cam bearing?
Old Dec 19, 2001 | 12:00 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I just pulled my old cam out and the fist bearing has like a notch in it. It this ok?
Old Dec 19, 2001 | 02:28 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Describe this "notch" in more detail.
It should have an oil hole, but no other deviations from "round".
Old Dec 19, 2001 | 02:33 PM
fast_broker's Avatar
Good front cam bearings have a GROOVE all the way around centered around the feed hole for oil distribution, not a notch, per se.
Old Dec 19, 2001 | 02:34 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Right, no "notches", should be a perfect cylinder...
The front one should actually have 2 oil holes. There are of course 5 cam bearings, of 3 part numbers: #1 is unique, #2 & #5 are one part, and #3 & #4 are another.
Old Dec 19, 2001 | 04:55 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
This is the 1st cam bearing. I see the oil holes. but this notch looks like a PERFECT small cut out on the outside of the bearing about a 16th deep and anout 1/8 high. on the drivers side. This mark was there when i pulled the old cam out and I inspected the cam and the cam looks perfect. I installed the new cam already in hopes this is normal.
Old Dec 20, 2001 | 09:48 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Ive seen that before, is It a V shape cut out, about this size ( .V. )? I cant remember which bearings they were or if I even looked but I personaly wouldent want it there. From what Im thinking it's put there to retain more oil. But the engine I saw it on had all the bearings cut that way.
SSC
Jorlain
Oct 8, 2015 01:57 AM
angel2794
Sep 8, 2015 06:22 PM
z28guy134
Sep 1, 2015 11:50 PM
masonta
Sep 1, 2015 06:40 PM
anesthes
Aug 26, 2015 01:37 PM
