min idle adjustment confusion
Old Sep 8, 2015 | 08:31 PM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
I know this topic has been beaten to death, but can somebody clear this up. On the Tech section the procedure says
Jumper the ALDL
turn on ignition & wait 30 seconds
remove the IAC connector
start engine
adjust idle screw to min idle
turn off car
plug in IAC connector
start engine.
At what point do you remove the jumper on the ALDL? There is no mention of that.
Every time I see something written on this topic it varies a bit. Just trying to nail it down.
Old Sep 8, 2015 | 08:41 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: min idle adjustment confusion
Jumper the ALDL
start engine
turn off car
start engine.
ANYWHERE between actually removing the IAC connector and the final restart will work. Once you jumper the diag terminal and remove the IAC connector the ECM no longer has control of the IAC. I prefer to remove the jumper before starting the engine to set the idle speed as the timing is generally fixed at a value the ecm will never use when the engine is running without the jumper.
mdtoren
Aug 23, 2015 12:52 PM
86IROC112
Aug 21, 2015 07:20 PM
mdtoren
Aug 16, 2015 05:45 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
