car won't start
Old Sep 11, 2015 | 09:18 AM
KarlJ's Avatar
car won't start
Got a 91 z28 305 tpi. They removed smog pump.
But I tried and start it. Nothing.
I put the timing on it and was timed right, getting spark , getting fuel but will not start
Air is coming out of the throttle body
Old Sep 11, 2015 | 06:12 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
Re: car won't start
Air is coming out of the throttle body? Can you clarify that?
Old Sep 15, 2015 | 03:48 PM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
Re: car won't start
you mean to say. you have a vacuum leak? TB's are intake only. Unless timing backfire.
Old Sep 15, 2015 | 08:29 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: car won't start
How did you time a car that will not start ?
Old Oct 5, 2015 | 04:10 AM
Tat2shag's Avatar
Re: car won't start
How do you time a car that wont start
Old Oct 9, 2015 | 03:43 PM
Piston454's Avatar
Car: 1990 RS Camaro
Engine: 400 sbc throttle body
Transmission: world class t5 manual
Axle/Gears: 3.73's, Detroit TrueTrac
Re: car won't start
I assume you are talking about the "timing gear and chain?".... like everyone said you cant set the timing on a car that wont start. but if you have air coming OUT of the throttle body... then you have your timing gear on wrong and your intake valve is open on the compression stroke.
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
killer777
Aug 8, 2015 02:47 PM
