starter problems
Old Sep 23, 2015 | 10:42 PM
mcbitchman's Avatar
Car: 84 s/e, 94 must conv, 66 must
Engine: 2.8 v6
Transmission: 5 speed manual
Axle/Gears: 3.42 posi just chngd from 3.73
starter problems
does my 1984 v6 SE have a starter relay switch ??? sometimes when I try to start I get a sound like a Ford solenoid with a low battery.... I replaced the starter and cables but still get the noise sometimes w/o starting ... never seen one so....
Old Sep 30, 2015 | 01:00 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: starter problems
Never heard that these cars have a starter relay. If it had a Ford type, you would have seen it when you replaced the cables.
Check the voltage on the purple wire at the starter when in start mode. You may have a voltage drop problem, which can happen across connectors and switches (ignition, clutch safety).
Spyder_TheGamer
Dec 25, 2015 05:07 PM
5spdcamaro
Aug 28, 2015 02:12 AM
92camaroJoe
Aug 13, 2015 06:07 AM
milk
Aug 10, 2015 06:26 PM
