AC/Heat causes car to miss when turned on
Old Sep 25, 2015 | 01:52 PM
BrianI's Avatar
Car runs great until you turn the climate control on. The car starts bucking/missing very badly. It's not as bad when the fan is on low but it's terrible on the other 3 settings. Has anyone experienced this before?
Old Sep 26, 2015 | 06:24 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: AC/Heat causes car to miss when turned on
The brushes in the fan motor may be shot. This causes a lot of electrical noise in the system which foo-bars the sensor values and ECM response.
RBob.
Old Oct 3, 2015 | 12:57 PM
BrianI's Avatar
It turns out that the wipers and blower motor kept turning off together. It has a wiring issue that I've found so I think that's the problem. Will try to post a pic when the weather clears up
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Exxon Limited
Aug 9, 2015 08:13 PM
Fronzizzle
Aug 9, 2015 01:15 PM
