Need cam advice!
Old Oct 21, 2015 | 01:19 AM
dannythebaldman's Avatar
Need cam advice!
Hey guys im almost done with the build of my 406 sbc it has a series 9000 crankshaft 3.75 stroke with 4.155 pistons -6 with 4 valve reliefs and 5.7 rods it also has brodix ik 200 64cc 2.02 intake 1.96 exhaust heads with .575 max lift springs. Ive tried Cams 12-444-8 and 12-443-8 and the exhaust valve keeps hitting the piston. Should i just take it one step lower? Or is there any other cams you may suggest or what can i do to fix this?
Thank you!
and 12-443-8
Old Oct 21, 2015 | 10:42 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Re: Need cam advice!
I don't think your cam choice is the issue here.
I wouldn't recommend just dropping down on cam without correcting the underlying issue. Hitting now at static means you'll still be hitting at high rpm with only a slightly "smaller" cam.
I'm thinking either:
1. Cam not degreed properly. could be retarded since exhaust is hitting.
2. Insufficient deck clearance. What does it measure?
3. Wrong valve reliefs in pistons (need to be for conventional 23 deg heads)
Old Oct 21, 2015 | 02:11 PM
Night rider327's Avatar
Car: 1988 Camaro
1.96" exhaust valve??? Is that correct or a typo... I'm guessing it's a typo though as I have never seen a 23* sbc with an exhaust valve that large.
If that is correct that is why the exhaust valves are hitting. That is too big for std. common 23* angle sbc parts/install
By "-6 with 4 valve reliefs" I'm guessing you mean 6cc flat tops.
I have found most small cc 4 VR flat tops do not have deep enough valve pockets for big cams. You can sometimes fudge that by installing cam advanced or retarded but that just barley gets you by on 240+ degree cams
I find it best if using flat top pistons to run a 5-8 cc 2 VR piston... Common sense tells you the valve pockets are twice as deep on a 6cc 2 VR piston VS. a 6cc 4 VR piston.
At this point you can fly cut your pistons to make the valve pockets bigger.
But before that, check, measure, measure, measure your deck height, gasket thickness, degree your cam in, etc.
You may get lucky and find that your cam is installed retarded from advertised.
To run my 249/252@.050" .570"/.579" lift cam, I had to use deep 2 valve pocket pistons. Wiseco pro tru 5cc 2VR (it's a 355 cid).
With that I run a .025" in bore at TDC, .015" thick gasket, Brodix IK 200 heads, 2.02"/1.60" valves.
87v6Bird
Oct 12, 2015 08:01 PM
scott13676
Oct 12, 2015 07:22 PM
racereese
Oct 9, 2015 07:23 PM
WASyL
Oct 7, 2015 12:46 PM
GTAman
Sep 26, 2015 02:01 PM
