oe roller cam install tool?
Old Oct 27, 2015 | 10:21 AM
mrestrictrplate's Avatar
Car: 87 Iroc 5.7,67 SS Camaro,90 Formula
Engine: 355 AFR Superram LPE 219
Transmission: 700r4 3000 stall 4spd 5 spd
Hello. I'm putting a lpe 219 in my l98. Motor is out. Everywhere I look I see tools, install handles for flat tappet cams. They say do not fit oe roller cams. I've installed flat tappet cams before and used bolts. Do you guys use the same thing for oe rollers? I don't want to nick the cam bearings. Thanks Chris
Old Oct 27, 2015 | 10:28 AM
Twin_Turbo's Avatar
Re: oe roller cam install tool?
the bolt circle on a roller is smaller. however just use a long bolt, it works just fine
Old Oct 27, 2015 | 10:33 AM
Thats how I did it on flat tappets. It's been about 15 years now so wanted some ideas. thank you
Old Oct 27, 2015 | 11:07 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I use 1-bolt and the timing sprocket myself.
Old Oct 27, 2015 | 02:21 PM
Damon's Avatar
Turn the block up on it's end and drop the cam straight in. Works every time.
(Please don't do this. It was just a joke.)
Old Oct 28, 2015 | 10:47 PM
Actually, works GREAT, if you put the sprocket on it first. Prolly go RIGHT THROUGH the plug on the back if you didn't.
Old Nov 1, 2015 | 09:09 AM
Vader's Avatar
Meh, if you're that far into it the build probably warrants a new plug kit anyway.
Old Nov 2, 2015 | 03:39 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
quadrajet mounting bolts are perfect for this.
spencer.24112
Oct 28, 2015 07:01 AM
budfreak1
armybyrd
Oct 27, 2015 11:15 PM
ndndndnd
Oct 27, 2015 05:00 PM
Nighthawkf-117
Oct 26, 2015 08:06 PM
