Thinking about going to 383, some ????
Old Dec 20, 2001 | 03:52 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I have an L98 '87 IROCZ with lots of mods, please see signature below.
Who makes a 383 stroker kit which is balanced and all forged items at a reasonable price (under $2,000)? I have a block with a single piece rear seal, so that has become an issue for stroker kits.
Should I go with 5.7" or 6.0" rods?
What about 5.85" rods? (Summit racing has these)
I plan on using my factory block and have it bored out 030 and have it releived for clearance. Also, I will have it machined for 4 bolt main caps.
I have been burning my own Eproms. Any special advice here other than I will need more fuel?
I would appreciate any comments or advice from those who respond.
TIA
Old Dec 20, 2001 | 04:20 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
check with this guy-
http://www.dyno-flo.com/
e-mail him and he will give you a quote on a complete assembly. I got a rotating assem for a 400 with free shipping for about 1200.
Let your rod choice depend on what pistons you can get. I would not get 6inch just for the sake of it. It will not really provide an HP increase. The 6inch rod on a 383 stroke requires the ring grouves be put in a real narrow area. If your going to use any NOS or boost, reducing area between the rings is not a good idea.
A 5.85 rod would work well, but you will have a little trouble finding a light piston. Try to find something in the 500 gram range for a 5.7 rod 383 and it will last a long time even with spray.
Old Dec 20, 2001 | 04:23 PM
un4givin89's Avatar
Power house offers the orginal 383 stroker kit complete, http://www.enginekits.com/383stroker.html
midge54
Jan 29, 2017 07:00 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
86White_T/A305
Aug 17, 2015 12:16 AM
sreZ28
Aug 14, 2015 07:48 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
