Throttle Sticking
Old Dec 13, 2015 | 08:40 PM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
Throttle Sticking
Throttle is sticking in my 305. Not constant but every now and then usually in the same pedal position. Going to start with the basics and spray it all out with some carb cleaner. Should just be gunked up?
Old Dec 14, 2015 | 08:04 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: Throttle Sticking
Gunk. Sure, that's the most likely cause. Possible cable binding, Possible weak spring too.
Old Dec 17, 2015 | 07:54 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
not sure if you're TPI or not but when the throttle shaft bushings wear out it causes slop in the shaft allowing it to bind up on the bores of the throttle body. the easy way to check is to try sliding the shaft left to right or up and down, there shouldn't be any play
Old Dec 18, 2015 | 11:21 AM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
Thanks for the tips! I sprayed it with wd40 and it seems to have fixed it!
'91CamaroRS
Brakes
Dec 14, 2015 01:07 PM
michael pippin
Dec 14, 2015 12:06 PM
bubbaz28
Carburetors
Dec 11, 2015 08:31 PM
Jake_92RS
Dec 1, 2015 04:17 PM
THIRDGEN87
Nov 23, 2015 07:29 AM
