Spark plugs for vortec heads
Old Dec 15, 2015 | 08:17 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
What spark plugs go in a 906 vortec head I want the original ones that came in the vortec heads from a 5.7 350 (1998-2000)
Old Dec 15, 2015 | 08:40 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Spark plugs for vortec heads
they "are" slightly longer than the ones on earlier 350's . I don't recall the number but I got AC delco's for a 3/4 ton G.M. P/U . have been fine for me . good luck ...
Old Dec 15, 2015 | 09:03 PM
Engine: LR4 4.8
Will these plugs work with shorty headers or will they cause clearance problems like rubbing on the headers ???? When u hook the wire up to it
Old Dec 15, 2015 | 09:09 PM
Night rider327's Avatar
Car: 1988 Camaro
AC delco 41-942 was factory IIRC
AC delco R44LTS6 is the std vortec plug
Auto lite 605
NGK V power 3951
Old Dec 16, 2015 | 07:40 AM
UNCLE TOM's Avatar
I have hedman shorty's #68478 on my car , no problems . I also have custom made right angle (90 degree) 8.5 plug wires . good luck ...
Old Dec 16, 2015 | 12:22 PM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
I pulled the # from a 97 truck, then had the guy at the counter bring me each of the available plugs. Champion was the shortest on the insulator side. Ive ran them for years now without burning a boot.
I can try and get the number this evening. Got the box in the garage.
Old Dec 16, 2015 | 06:47 PM
Engine: LR4 4.8
Yea I wish I had hedmen shorties but the car when I bought had flowtech shorties and y pipe already on so I'm not gonna swap out a 350+ dollar exhaust just to swap to hedmen which would be about the same price but I'll buy one of the vortec plug and test fit if not I'll have to get those accel shorty plugs which I really don't wanna use
Old Dec 17, 2015 | 06:45 PM
L98GTA87's Avatar
Car: 1987 Trans am
Engine: 350 Vortec Stealth Ram
Axle/Gears: 02 SS Torsen Zexel 3.42
What flowtech headers you have? I just put a set on my vortec 350 and the plug clearance is the absolute best I've seen so far coming from 2 sets of longtube headers.
I have the autolite ap 104 plugs.
Old Dec 17, 2015 | 08:09 PM
3rdgenmaro's Avatar
Car: 88 IROC
Rs 14yc. Champions is the ones I'm running I think. Empty box in my camaro stuff. I'd have to google the number to make sure if the right reach. Do not waste your time with accel shorties. They don't last. Went through 2 sets before I learned
Old Dec 21, 2015 | 08:49 PM
Engine: LR4 4.8
yea the accel are the ones im using now the only reason why im using these is because I pretty sure the standard size plug will hit on the headers and burn up plug wires which I don't want to happen
Old Dec 22, 2015 | 06:29 AM
3rdgenmaro's Avatar
Car: 88 IROC
I understand, that's why I ran them too. I just couldn't get any life out of them. But the champion is very short as well and I haven't had any issue with burning the plug wires on my headers. I will try and get a comparison pic if I can. Im fixing to order a new set.
Old Dec 23, 2015 | 09:15 PM
Engine: LR4 4.8
That would be great if u can get mostly the lenght of the plug with like a vortec plug that would be great
Old Dec 25, 2015 | 09:40 AM
3rdgenmaro's Avatar
Car: 88 IROC
Will do. New plugs are on order but I can take a pic later of tube clearance
Old Dec 25, 2015 | 05:23 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
I'm using NGK TR55's with my Vortec heads and Edelbrock headers.
Old Dec 29, 2015 | 08:37 PM
Engine: LR4 4.8
Ok everyone so I did some test fitting today and it seems like a normal lenght plug will clear just fine with the flowtech shorty headers looks like I'll be picking up a full set of vortec plugs hopefully this weekend I'll keep everyone posted on how it turns out hopefully the car will run now with these instead of those crappy accel ones
Old Jan 10, 2016 | 07:48 PM
3rdgenmaro's Avatar
Car: 88 IROC
I finally went and got my plugs and took a pic comparing the champion to the overrated accel shorties. Look over the fact that the accel isn't a vortec plug. Previous owner ran the wrong plug.
Old Jan 10, 2016 | 10:49 PM
Car: 1988 Camaro
Nice.. Looks like the champion might be 1/16" to 1/8" longer. Not bad at all
Old Feb 1, 2016 | 04:12 PM
Engine: LR4 4.8
Yea I installed my vortec plugs a couple of days and the car still doesn't want to run I think it's something wrong with the tuning file I'm using I don't know what else it could be
87GTA5.7
Dec 18, 2015 07:52 AM
mrestrictrplate
Dec 14, 2015 11:43 AM
Zylinder
Dec 14, 2015 01:53 AM
neilcase
Dec 13, 2015 05:22 PM
mrestrictrplate
Dec 11, 2015 10:25 PM
