Will OEM air cleaner still fit?
Car: 1986 Pontiac Firebird s/e
Engine: 305 Chevy
Axle/Gears: 2.77 for now
Sirs,
I am having an Edelbrock intake 3701 installed in my car. It is around an inch and a half taller than the OEM intake. Will I be able to bolt back on the OEM air cleaner and still be able to close the hood? thanks, gents.
re: Will OEM air cleaner still fit?
Probably not.
If you have a Camaro, your odds are better. It certainly won't fit with the Bird hood.
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
If it does close it will rub. I went with an edelbrock air cleaner for my 86 to fix the issue.
Engine: 305 Chevy
jharrison5,
Trying to do an OEM resto on this firebird. So it's got to look like it came from the factory as much as possible.
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Copied from the thread in the Carb section:
"w41, I don't think you'll have a problem.
The car in my sig runs a Vortec/Q-jet Edelbrock Performer 2116, height of 4.57" as opposed to your 3701 height of 4.02".
The stock air cleaner just touches the Formula hood and wears the paint from the front edge of the air cleaner lid.
I'd be surprised if your hood has an additional 1/2" of structure inside it compared to mine. For all I know the s/e and Formula hood are one in the same."
Transmission: 4L80E/4L80E
Re: Will OEM air cleaner still fit?
The 3701 is ~1/2" higher at the carb mount than a stock intake manifold. You shouldn't have any problem with the stock air cleaner, other than the breather tube to the valve cover may barely reach.
gtopat
Nov 9, 2016 01:22 PM
trackbird
Nov 25, 2015 01:44 PM
