tweaks
Old Dec 21, 2001 | 05:53 PM
MCMLXI's Avatar
tweaks
I'm just wondering what little tweaks i could do to my car to get a little more out of it. Like grinding the plenum etc.. Thanks
Old Dec 21, 2001 | 05:57 PM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
is it TPI?
some guys say that gutting the MAF screens helps.. i wouldn't do that, but that's just my opinion..
unbolt the little flaps in your airbox to open up some air..
some guys take out the foglights and run tubing from behind there up to the intake plenum
port the crap out of that big hump right behind the throttle body on your plenum
get an airfoil
gasketmatch all TPI surfaces
good tune-up
supposedly running 92 octane for awhile will allow the computer to adjust to the higher octane and it will advance the timing more (i can't see why spending 10% more on gas equates to a good cash investment, though)
make sure your TPS voltage is on target, having it misadjusted definitely can take away the snappy off the line feeling..
uhm, what else.. maybe run soem fuel injector cleaner once or twice to make sure everything is clean? balancing fuel injectors is expensive but imo worth it..
change your oxygen sensor
Old Dec 21, 2001 | 06:07 PM
MCMLXI's Avatar
Yes it is TPI , Thanks for the tips
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
Billgluckman
Members Camaros
36
Nov 24, 2015 07:29 PM
ezobens
Aug 19, 2015 10:29 PM
87_Camaro
Oct 16, 2001 09:05 AM
