Quick question about B&M shifter installation...
Old Dec 21, 2001 | 10:52 PM
BAK12484's Avatar
Tomorrow im gonna be installing my new B&M megashifter, and tonite i was reading over the directions and have one question that i hope you guys could answer...
in the instructions it talked about how on some models of camaros there are two extra wires connected to the wire connector...supposedly they lock out the converter clutch and change idle speeds in neutral and park.. It says that you can connect them on a relay (bought at radio shack) and it will restore it to the normal function.... now my question is if this is really necessary or not?? Will my car run fine if i decide not to wire in the relay??
BTW, my car is a 1990 Camaro
TIA
Old Dec 21, 2001 | 10:55 PM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
here's a link to a review for my website by one of my moderators..
http://www.gmperformance.org/modules...owcontent&id=4
he loves his megashifter.. if you look at the bottom of the review you will see his email address..
i'm sure he'd be more than willing to help you out
later man!
Colin
Old Dec 21, 2001 | 11:30 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
A big hint, don't use the cable they give you, it's junk. It has broken on numerous people, I used the stock cable, and so have others. Didn't even require getting under the car. You will have to do some minor fabrication (takes about 5 mins), you'll have to cut a bracket and drill a hole. As far as the relay, I didn't install it, I've heard other on these boards that haven't and don't have any problems. Do a search on the topic and you might get some more answers. Supposedly, if I remember correctly the only way not having the relay installed will affect your car is if you're doing 35mph in N or something like that. Another tip, don't ever put Armorol on the boot or it will fall apart. Also use lock tite on the handle or it will strip.
Attached Thumbnails Quick question about B&M shifter installation...-intcamaro.jpg
Old Dec 21, 2001 | 11:38 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Everything Mark said seems to be the general consensus around here. However, I used the supplied B&M cable and haven't had a problem with it yet. As for the relay, I didn't use it and haven't experienced any problems from it.
Old Dec 22, 2001 | 12:08 AM
SpeedCat86's Avatar
Car: '86 TransAm WS6
Transmission: Custom TH700R4
Yeah, I agree with ViciousZ, That everyting works OK. I, though installed the relay, 'cause my car goes nuts if you try any monkey bizzness with the electronics. The relay isn't hard to install if you plan ahead, and don't mind doing some soldering. I had no trouble with the cable for two years, untill I got my new trans. The shop didn't put the cable in the right way (the way they tell you) and it split about a month later. The new one has been on for about a year, and no problems.
P.S: Why does everybody have the t-handle mounted at a 45 degree angle? MIne is straight across. Just wondering....
Old Dec 22, 2001 | 12:41 AM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
Keep this stuff coming guys, I'm thinking about buying one of these
Old Dec 22, 2001 | 12:43 AM
Engine: 305TPI
Hg,
the moderator on my site gave it a 4.5 stars out of 5 recommendation..
the link to his review is posted above in one of my other replies
Old Dec 22, 2001 | 01:09 AM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
speedcat, they mount the t-handle at 45º because they don't have the nut below the handle to lock it into place. Instead they just tighten the handle all the way down. I also took care to route the B&M cable correctly, and no problems.
Old Dec 22, 2001 | 02:03 AM
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
If they dont have the nut on the threads they cram alittle bit of paper in the shiter **** hole so it wont screw down that much. (its ghetto) but it should work. I used to have the mega shifter with my old 700-r4, and now that im back to Auto, I need to get anotherone since I sold the other one
Old Dec 22, 2001 | 08:31 AM
Car: 99 Formula
Axle/Gears: 342
NO, that's not the reason. My dad put it on that way, and I was like what are you doing. He said that's how they use to do it in the day, I was like ok, actually it fits your hand better at that angle. Plus I think it looks better.
Old Dec 22, 2001 | 09:51 AM
Chevy83Z28's Avatar
I find the 45 degree angle on the T-handle easier to use than if it were straight. And I chose not to install the relay, and have had no problems w/o it... but there's one code in the computer (not sure which # it is) that I think is caused by not having the relay installed. However, the code doesn't trip the check engine light and doesn't seem to even matter . Good luck and I think you'll like the shifter.
P.S. does anybody notice when you downshift it rocks the top of the console? That's the only downside of the shifter I've found so far--its hard to downshift and loosens up the screws a lot. (not so bad because you don't need to downshift in a 1/4 mile race..)
Old Dec 22, 2001 | 08:35 PM
Bort62's Avatar
I have my handle upside down, my Hand is too big to fit it Normally
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
