Info on porting miniram 2 runners?
Old Jan 21, 2016 | 08:27 PM
rithsleeper's Avatar
Just some curiosity, but I've got my engine running and I'm wanting the absolute best out of it.
I feel like there is a ton of meat left in the runners even though I have the 1206 version of the miniram 2. Afr 210's seem just visually to have bigger runners than the miniram's which is not ideal for a clear air stream. Anyone have any experience with this or have any good articles that aren't generic "smooth all the bumps and match to intake manifold".
engine:
383 with 210cc AFR heads. Cam is pretty aggressive with solid roller lifters producing ~.625 gross lift. Engine can spin to 7k because it is a road racing application. Static compression just under 11:1 but cam has enough overlap to run pump gas.
rickyzZ28
Wheels and Tires
Jan 19, 2016 10:00 PM
86z.28
Jan 14, 2016 04:17 PM
jpearcy1
Jan 4, 2016 10:51 PM
