Installing aftermarket oil guages
Car: '02 T/A
Transmission: 4l60e
I've got an autometer electric oil temp and oil pressure guage. Install seems pretty simple but I was wondering which ignition wire I should use for these? Also will both work off of the one autometer sender mounted by the distributor?
Re: Installing aftermarket oil guages
Use the Gauges feed. Should be able to get one of those clippy things that goes under a fuse.
No you can't use the same sending unit. For one thing, it will be specific to the quantity it's measuring: a pressure one (usually a spring-loaded diaphragm kind of thing) will be specifically designed to be insensitive to temperature, and a temperature one (usually a semiconductor substance whose resistance decreases as it gets hot) is totally unaffected by pressure. For another, at that physical place, the pressure one will be quite accurate, as it's exposed to a pressurized oil passage; but a temperature probe mounted there will tell you block temp, not oil temp. An oil temp sensor needs to be in the pan, submerged in the oil sump.
Car: '02 T/A
Transmission: 4l60e
What did you mean by guages feed? And clippy thing by the fuse?
I mean, the power that powers the gauges. Comes off of a fuse labeled "gauges" or something similarly cryptic.
They make a thing you can plug into the fuseholder, and then you plug the fuse into that. It has places you can attach more wires to.
Pull the "gauges" fuse, put the adapter thingy in, put the fuse back, connect a wire to the fused side of the fuse via the adapter thingy, and run it to your new gauges.
Car: '02 T/A
Transmission: 4l60e
would you be talking about an add-a-fuse or a fuse tap? I came up with those with a Google search. Thanks for the input I had no idea these existed!
Yup; that would be the one. Sorry, my brain got a cramp, and it couldn't remember their "name".
Car: '02 T/A
Transmission: 4l60e
No... really, a 1A would be entirely adequate if such a thing existed. Gauges use VERY LITTLE (emphasis on VERY) little power. Although if memory serves the smallest one you can get is a 3A, which is still like about 10 times as much as the entire instrument cluster really needs, but the wires are much larger than that. All the fuse needs to do is keep the wire from starting a fire if your hookup screws up and a wire touches sheet metal.
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Sofa- I've got an oil temp gauge I'll be installing when I pull the engine again. Was wondering if mounting the oil temp sensor (via welding a bung) in the oil pan was the better place or just sticking with the extra port on the china wall by the dizzy?
If the sensor is up on top of the block, it will measure block temp at that point, not oil temp.
To measure oil temp unambiguously and without interference from anything else, the sensor pretty much needs to go in the sump. If you had a dry-sump system it could go in a line somewhere but putting it in a casting will make it measure the wrong thing.
Car: '02 T/A
Transmission: 4l60e
With that being said is an oil temp guage with the sender by the oil filter not that accurate?
What will it be measuring the temperature of at that point? An ounce of oil or 200 lbs of cast-iron? Will the temp of that little spot on the block really be even affected materially at all by the oil nearby, let alone independent of the rest of the casting?
The right place for an oil temp sending unit is in the sump or in an external line that is at oil temp not casting temp.
Car: '02 T/A
Transmission: 4l60e
One more question- for the 12v source of the aftermarket guages I'm adding, does each need its own source/fuse plug in? Maybe I'm just overthinking this.
It is perfectly acceptable to feed more than one gauge from the same +12V power source , since the factory setup feeds them all from that same "gauges" fuse . In fact , were I doing this , it would be the gauges power source that I tapped into for the +12 to feed the aftermarket gauges . As Sofa said , gauges draw VERY small amounts of power to display their readings * and so multiple gauges fed power from the same source is fine . * The exception being of course that an amp gauge with it's shunt built in must be placed in series with all electrical devices except the starter motor itself and the battery . This was seen very commonly on cars up till the late 60s / early 70s when cars got far too many power accessories to be putting the load through a dashboard mounted gauge . At that point they began monitoring volts rather than amps with regards to the charge/drain status of the battery .
Car: '02 T/A
Transmission: 4l60e
Just trying to picture this. What would be the easiest way to go about connecting the 12v wire from each guage (3 aftermarket) into the one guage fuse?
I hope that helps some and if you have any other questions feel free to ask ..
