Engine out...new oil pump, replace pickup too?
Old Jan 27, 2016 | 05:06 PM
Abubaca's Avatar
Hey guys....basic question. Do I need a new pickup? ....I purchased a 383 shortblock from a good friend of mine. Less than 10k miles, built well beyond my needs. Engine had no issues, but my understanding was that it would be a good idea to swap oil pumps while I was in there. Picked up a melling 55hv, since that's what it had, and it has a gazillion positive reviews on pretty much any site you look at. I had just assumed that with no moving parts, and such low miles...the pick up would be fine to re-use. Thoughts???
The pickup for the 7qt. Moroso pan is like $45 bucks. Now....that's not a lot of money, but it IS a few cases of High Life.....and you know...."High Life"!
Old Jan 27, 2016 | 05:23 PM
Re: Engine out...new oil pump, replace pickup too?
Try taking a pickup out of a pump and moving it over to a new one... you'll probably decide to replace it
Old Jan 27, 2016 | 06:25 PM
Abubaca's Avatar
Yeah.....I wondered about that. I know it's not welded....but it's still press fit. May not be removable.
Old Jan 27, 2016 | 06:29 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
You could get it out of the original just fine, your problem would be getting it to stay in the new one, granted you should be tack welding in place.
Old Jan 27, 2016 | 08:23 PM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Unless something really unusual happened with that engine, there is NO need to replace the pump nor the pickup.
Old Jan 27, 2016 | 08:57 PM
Night rider327's Avatar
Car: 1988 Camaro
With only 10K miles on build, no reason or need to replace pump or pickup.
Old Jan 27, 2016 | 09:12 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Do yourself a favor, trade that 55HV for a 55A.
No need for a high "Volume" pump unless you have excessive bearing clearance.
This has been said many, many times.
85@IRocZ
Feb 1, 2016 08:09 AM
dpmalibu
Jan 27, 2016 07:44 AM
85@IRocZ
Interior Parts Wanted
Jan 20, 2016 03:11 PM
Dinero
Jan 10, 2016 10:40 AM
tn_camaro
Jan 3, 2016 11:12 PM
