Do I need a billet timing cover for a retrofit cam/cam button?
Old Feb 17, 2016 | 10:27 AM
Abubaca's Avatar
So...doing a cam swap on my non roller 383. The old, AND new set up is a Lunati retrofit cam, and I have a billet cover. Guy who built the motor said it was necessary. I've thrown around the idea of using EFI Connection's 24x set up, which requires a cam sensor, which means the composite vortec timing cover. I would think the pressure on the cam would pull it back towards the oil pump gear, right??? ....but I see other people mention heavy duty or billet covers for retro set ups too.
...anyhow....figured I'd ask.
Old Feb 17, 2016 | 01:54 PM
mrestrictrplate's Avatar
Car: 87 Iroc 5.7,67 SS Camaro,90 Formula
Engine: 355 AFR Superram LPE 219
Transmission: 700r4 3000 stall 4spd 5 spd
Re: Do I need a billet timing cover for a retrofit cam/cam button?
Luckily I had the engine out of my car when I went with a billet cober. I had to file down where the gaskey went because it was not machined right. Guaranteed leak... I guess that's what you get with a $40 dollar speedmaster cover versus a $200 comp cams billet cover. I hope it doesn't leak.
Old Feb 17, 2016 | 02:30 PM
UltRoadWarrior9's Avatar
Car: 1986 IROC Z-28
Engine: 383 Gen I SBC 11:1
Transmission: Rebuilt TH700R4 for 500+HP
Axle/Gears: 4th Gen 10 bolt Eaton Truetrac 3.23
I can't answer your question, but I got the Comp Cams billet 3-piece timing chain cover, part # CCA-310, for my current 383 build, so I don't have to disturb the oil pan seal when changing timing or cams. Gasket provided and overall product quality says made in the USA (so does the price , hell it's 1 time cost).
What block # are you using?
Old Feb 17, 2016 | 02:59 PM
Abubaca's Avatar
I don't have the block # with me here at work. I can look at home. I KNOW the existing billet cover works/seals with no problems. ....and the more I look at it, it's not likely I'll go with the 24x set up, in which case the existing billet cover will be used.
Old Feb 21, 2016 | 12:04 AM
cardo0's Avatar
Car: Fourth Gen '94 camaro
Engine: 350 Gen II
Transmission: A4
Ya, u need a strong cover and a cam button to keep cam movement forward and back
customblackbird
Aug 27, 2018 01:05 PM
bamaboy0323
Dec 15, 2016 01:08 PM
broke91firebird
Feb 3, 2016 04:10 PM
antares57
Jan 31, 2016 10:16 PM
Abubaca
Jan 27, 2016 09:12 PM
