Low oil preasure
Old Feb 21, 2016 | 09:23 PM
Mattkovitch's Avatar
Car: Firebird
Engine: 305 tbi
Low oil preasure
My oil pressure has been gradually going down. It idles just above the red and sits at about a little more than 15 most of the time but doesn't go much higher. Once I get past 1500 rpms the engine starts ticking. Any help is appreciated, really not wanting to have to dump money into rebuilding a 305.
Update: The oil pressure is at almost 30 when i start it up and the ticking was gone, but then gradually over like 10-15 minutes of driving drops to about 15 and the ticking came back. Higher rpms seem like they dont change it much at all.
Old Feb 22, 2016 | 12:06 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
Re: Low oil preasure
Does not sound good, what is the ticking noise? Lifters or a rod knock? Either way I suspect you will need a rebuild.
Old Feb 22, 2016 | 12:27 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Last oil change? Oil full? what brand of oil filter?
Old Feb 22, 2016 | 12:57 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Try some 20w50 if its wore out this heavy oil may quiet it down some but you probably looking to rebuild or replace soon im afraid.
Old Feb 22, 2016 | 01:04 PM
Camaro86IrocZ's Avatar
Car: '86 Iroc Z & '91 RS
Engine: 305 TPI & 305 Qjet - Future LC9
Add a bottle of STP oil treatment - http://www.walmart.com/ip/STP-Oil-Tr...-15oz/16817398
Adds extra zddp needed for pre '87 flat tappet cams. Fingers Crossed.. and a Pray..
Old Feb 22, 2016 | 04:00 PM
Car: Firebird
Engine: 305 tbi
Not sure what the ticking is. It's not loud or harsh, but just quietly there. And about the oil change that's the first thing I need to do, as I just bough the car about a month ago and haven't got it changed and Idk when they last did it. Really hoping I can fix it with some better oil or a new filter. If I do need a rebuild, how much does that usually cost? Any ideas?
Now that I think about it probably lifters causing the ticking.
Old Feb 22, 2016 | 04:13 PM
someone972's Avatar
Car: 1991 Firebird Formula
Engine: 5.7L TPI
I had a low-oil pressure issue on my engine where three of the four oil pump bolts had worked their way out. Perhaps not the source of your problem, but something to consider.
Old Feb 22, 2016 | 05:53 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Pressure is a resistance to flow. When the engine is cold, flow is reduced and you see pressure. As the oil gets hot, viscosity drops and anywhere it can leak out will be easier. The chances of the oil pump being bad is very slim. That means you'll probably need engine work. The ticking is probably a lack of oil to the lifters and rockers.
Main bearings worn will cause an oil leak but will not cause noise until a bearing seizes onto the crankshaft.
Rod bearings wearing will generally cause a noise when they start to fail but will also make noise hot and cold.
Camshaft bearings can spin in the block and will wear causing a hot oil leak that won't show when the oil is cold. They will also not create a noise.
Buy a new oil filter to replace the one on the car. Don't worry about an oil change yet. Take the old filter and cut it open any way you can. Even a hacksaw can be used. Just cut the top off. Pull out the filter material and rip a chunk of it out. Squeeze that piece in a vise to get all the oil out of it then open it up to look inside. If there's lots of metal in the material, you have bearings going. All the temporary help such as thicker oil won't fix an engine in need of a rebuild.
Old Feb 22, 2016 | 07:57 PM
nhgator's Avatar
Car: 1985 T/A
"All the temporary help such as thicker oil won't fix an engine in need of a rebuild."
There isn't much in a can that is a long term fix for low oil pressure or a tick..
Old Feb 22, 2016 | 08:35 PM
Car: Firebird
Engine: 305 tbi
Thanks for the help. I'll try looking for metal chips in the oil. If I do need a rebuild, does anyone have a ballpark figure of what that will cost?
Old Feb 22, 2016 | 09:07 PM
More than a 305 is worth.
IOW, if you get to that point, DON'T do it to your existing block. Put a "bore kit" in it. And a good set of heads. Those crappy "swirlies" aren't worth the time of day either, any more than a 305 is.
Old Feb 23, 2016 | 07:16 AM
AlkyIROC's Avatar
Car: 87 IROC L98
More than the cost to buy a stock replacement engine.
Old Feb 23, 2016 | 08:27 AM
Car: Firebird
Engine: 305 tbi
Thats what i thought. if I need a rebuild, then I'm just gonna run it till its dead while i save and then swap a 350 into it. How hard is it to find a good running junkyard 350 anymore? Or is there a better place to get one?
Old Feb 23, 2016 | 04:56 PM
96-2000 ones (aka Vortec) are pretty plentiful and not too $$$.
Old Feb 23, 2016 | 09:08 PM
Car: Firebird
Engine: 305 tbi
Augh well I guess I'm engine swapping this summer. Here's another question, what can I do to make this motor last as long as possible? Would thicker oil and an oil additive help? And how long do you think it'll last?
Old Feb 24, 2016 | 06:40 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
[QUOTE=Mattkovitch;6009672]...Would thicker oil and an oil additive help? ...QUOTE]
No and No.
Old Feb 24, 2016 | 07:02 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Old Feb 24, 2016 | 10:03 AM
Car: Firebird
Engine: 305 tbi
Any ideas on how to make the engine last as long as possible, while I get some money together for a 350 swap
Old Feb 24, 2016 | 11:04 AM
86LG4Bird's Avatar
Don't let it lug at low rpm. Raise the idle speed. Don't rev it over 3000.
Old Feb 24, 2016 | 03:03 PM
Could also be an exhaust leak, injector click noise, bad oil pressure switch making the gauge read off.. So hard to tell thru internet posts,, Make a vid so these guys can hear it for a better diagnosis..
Old Feb 25, 2016 | 02:55 PM
Car: Firebird
Engine: 305 tbi
I was hoping you're right, but I don't see it being probable as the ticking sound development right after the Gage started reading low oil pressures.
Old Feb 25, 2016 | 03:15 PM
Formula 305's Avatar
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
Does it have the proper oil level? It was asked earlier in the thread but I didn't see an answer.
Iroc_Lopez28
Jun 30, 2016 01:40 PM
1701-Z
Feb 1, 2016 07:49 PM
antares57
Jan 31, 2016 10:16 PM
Abubaca
Jan 27, 2016 09:12 PM
shugart111
Jan 25, 2016 12:26 AM
