Starter Stuck Running, Not engaging flywheel.
Old Feb 27, 2016 | 12:31 AM
Instinctz's Avatar
So 2nd day of owning my new old 1991 RS with 350 swap, it is a high compression build as I was informed by the previous owner and tends to knock the starter back when cold.
I went to start it this evening and it started to crank but then the starter disengaged the flywheel and is stuck running. I had to hop out and disconnect the battery's ground cable.
I've worked on a number of starter issues in the past but never have I had one stuck running, I'm guessing it will be a relay (solenoid) stuck somewhere possibly fused due to load shock but has this issue came up with anyone else in the past?
Any advice on a possible fix if you have heard of this?
Old Feb 27, 2016 | 03:39 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: Starter Stuck Running, Not engaging flywheel.
Usually when that happens the main power wire and the ignition terminal wires are making contact. If they aren't then it could be internal to the solenoid.
Old Feb 27, 2016 | 12:22 PM
Instinctz's Avatar
Could quite possibly be that the ignition and +12 supply where making contact. The ignition was loose enough to move by hand so I pulled it away from one side, and tapped on the solenoid while under there just incase. Back to operation.
Appreciate the comment on diagnostics, I sorta was overlooking that as a possibility for some reason hehe.
customblackbird
Aug 27, 2018 01:05 PM
mud runner
Feb 12, 2016 04:50 PM
evilstuie
Jan 29, 2016 04:14 PM
kzkorean
Jan 29, 2016 01:01 PM
Dr34m
Jan 28, 2016 09:27 AM
