Bad antifreeze leak
Old Feb 28, 2016 | 12:17 AM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
Bad antifreeze leak
Hey I need some help
I backed my car out to clean the inside and I let it run. No spots in the garage, while idling I noticed a huge puddle. Turned it off and checked coolant levels. Looked fine so I backed it by the garage and jacked it up. It is leaking under the radiator mount on two points in the center and passenger side. I looked and the usual suspects are okay, like the hose and water pump. No traces of coolant getting there. Ran it and the leak stopped. Then I left it parked, bam big leak huge puddle. I had the radiator and all cooling items replaced fairly recently. What could cause this weird problem?
Old Feb 28, 2016 | 12:56 AM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
Re: Bad antifreeze leak
she just dribbled it all out, having it towed Monday morning to the mechanic who put that faulty piece of cast iron in my car. Hoping for a free replacement.
Old Feb 28, 2016 | 02:06 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
The water pump has two"weep" holes on the underside.
If seal/bearing starts to give out coolant will start to drip/flow out the hole letting you know its bad.
If that the case a new water pump is necessary.
Old Feb 28, 2016 | 02:08 AM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
Originally Posted by Ron U.S.M.C.
The water pump has a "weep" hole on the underside.
If the bearings start to go out coolant will start to drip/flow out the hole letting you know there bad.
That's initially what I thought it was, that and the hose and the plugs in the radiator. Sadly I found zero trails of coolant. The only wet part is the radiator tray. May be cracked on the bottom
Old Feb 29, 2016 | 07:43 AM
Could be that, could be something as simple as the radiator cap or the hose to the coolant recovery bottle.
Old Feb 29, 2016 | 09:27 AM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
I thought so too, took out the airbox and found all hoses on the overflow to be intact with no visible leaks, and the cap seemed to be in good shape. The only place I could find it leaking is in the bottom radiator mount. No other place was wet, and it would be clearly visible since it dumped the entire system. The place should have my car pretty soon and hopefully then I can post back and answer to what happened.
Old Feb 29, 2016 | 01:48 PM
Ikes 91Z's Avatar
Car: 1991 Camaro Z28
Engine: LS Conversion
Axle/Gears: Stock for now...
Just a thought, but check the drain plug too. Could be loose or cross threaded.
Old Feb 29, 2016 | 04:23 PM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
Got a call back, radiator is cracked. It has been in the car less than a year.
SOCAL-Z
Brakes
54
Jan 4, 2022 03:08 PM
FireInMe17
Mar 19, 2016 10:53 PM
Mattkovitch
Feb 3, 2016 11:22 PM
BeyondZ28_85
Exterior Parts Wanted
Feb 2, 2016 11:06 PM
BobKnake
Jan 31, 2016 03:52 PM
