Thanks all who never replied when asking for help
Guess I was able to do it once again with the help of my shop elf. Last night went to garage to do some more custom trim of interior and on my floor was a small black piece of plastic. Low and behold it was the casing for my TPS. Apparently someone had opened it and tried glueing it back together. DUMBBELL of an ideal I say. Should find out later today if that was my issue of no spyder jet spray.
Re: Thanks all who never replied when asking for help
I know it's frustrating when no one answers your question , but consider this ;You are brand new here . No one "knows" you , in the chat forum sense as your not an "established" poster . So , along comes this stranger with a question , no problem so far , we answer questions for strangers all the time , it's how strangers BECOME "regulars" around here . But here comes you , a stranger , and your asking the ONE question we just about NEVER discuss publicly , a question of how to defeat the anti theft feature in these cars , a question that basically amounts to a how to guide for stealing a VATS equipped car ! Yes I know your story went that someone died and you got the car with no keys and that's why you need to defeat VATS , which may be all well and true , but it just as well equally could be true that you ARE planning to steal someone's VATS equipped car and we have no way of verifying which you are , due to the whole "stranger" deal . So , next time , before ya go gettin that size 10 chip on your shoulder , stop a minute and try to consider the other side ;
Let's pretend your a master safecracker . Some stranger asks you how to break into the exact same type of safe you own at your place to hide your stolen gems in . How much info are you gonna give out regarding the security system protecting something you yourself own ?
OK so I have a crazy back story about my 91 rs. I was given the car and extra engine on stand not sure what the engine is just that its a Chevy motor the car was a guy who got shot and is no longer around but guys mom and brother said to get them out his house because they sold house.nevertheless I towed it home I have no keys and my dumb *** busted ignition and steering column to get home. Not realizing there was a little thing called VATS well I'm pretty sure I've bypassed all that now and to my issue no starting. I can only get my spyders to spray if I use test light on blue or green wire and touch ground while cranking but seems I have no pulse to keep them spraying. I'm lost would surely appreciate any body's help where I go from here.
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Additional considerations;
1) Getting people to understand what your problem is. What is a "spyder"? Anyone that works on cars calls these "fuel injectors". If people can't understand your question, you are unlikely to get people to put additional thought into figuring out your problem.
2) Time to respond. People don't live on TGO... well, some might.
So the people who can help you with your problem might not see it for a while. The time between your first post with a question to your second-ever post now complaining that people won't help was just 24 hours. You would have been better off replying to your original thread to bump it with an... Anyone? Bueller?...
Welcome to TGO, and good luck getting your 91 Camaro running!
So the people who can help you with your problem might not see it for a while. The time between your first post with a question to your second-ever post now complaining that people won't help was just 24 hours. You would have been better off replying to your original thread to bump it with an... Anyone? Bueller?...Welcome to TGO, and good luck getting your 91 Camaro running!
Car: 1994 Z28
Engine: 355 LT1
Disconnect the tube that ejaculates fuel into the spyder jet sprayer rail. (Note: not the side that is after the regulator that sucks down the ejaculated fuel).
Now, follow one of the rubbers with the sneaker at the end (you have 8 of these coming off your dizzy and running down to the emission plagued heads). Take the sneaker end you pulled off the arc sparking plug and jam that tube (that ejaculates fuel to the spyder jet sprayer rail) into the sneaker.
Now crank the engine vigorously for about 30 seconds non stop and it will fire right up!
Car: 89 IROC
Engine: l98 350 TPI
Axle/Gears: 373s
lol zraffz. Where did you get the term spyder? And if you still have VATS problem, the search will bring up many discussions about defeating it.
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
Car: 1994 Z28
Engine: 355 LT1
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Hey Orr89RocZ , I'm just curious , since your post is directed at the original poster , who is 3rdgentofourth , why did you quote my post in your reply to him ?
Car: 89 Iroc-z
Transmission: TH400
No idea
I quoted your post as it contained the orginal op question but it didnt copy over
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Uh there is also this space on the left hand side of the screen that you can fill with all sorts of info about your car and where you're at... Maybe someone on here is in your area and would be willing to help... I have been known to help out random people on occasion...
Transmission: 4L80E/4L80E
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
I often wonder why the rectal orifice that started a post like this one never has the ********* to reply . oh well , one of the great mysteries of life ...
Either he WAS tryin to steal a VATS equipped car , or , He got angry at the responses here and went away all butthurt , or , he fixed it (or gave up on it and lit it on fire) .....
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Well, I for one would like to say "you're welcome" to all the people that never thanked me for the times that I was able to help them.
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Car: Sport Coupe
Engine: 3.4 MPFI
Transmission: WC T5
I would like to thank the OP for posting this so that the following hilarity could ensue.
zraffz, you are my hero.
hotrodjames
Mar 31, 2016 05:00 PM
hotrodjames
Mar 23, 2016 02:05 PM
