1988 firebird formula 5.0 tbi rpm needle jumps
Old Mar 10, 2016 | 06:52 AM
Randomtask2's Avatar
Car: 1992 Pontiac Firebird Formula
Engine: 5.0 305 tpi
Transmission: T5 (5 Speed) lol
Axle/Gears: stock posi
OK, I just brought the car back out of storage. Before it was parked had no issue. Battery was dead for a couple months.The car is running absolutely fine prior. But for some reason the RPM needle is jumping like crazy at idle only. When it's running fine, and not idle surging. Even hooked up to a scanner. Idle is around 700. I unplug a random vacuum line. And has higher idle. But doesn't jump around. Is my rpm gauge messed up. Because the last thing I did for the issue arrived originally, was I replaced the distributor. And followed instructions. Any information for me? Anything will help, seriously.
Old Mar 10, 2016 | 07:06 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 1988 firebird formula 5.0 tbi rpm needle jumps
A jumpy tach is typically caused by an issue in the secondary side of the ignition system.
RBob.
Old Mar 10, 2016 | 07:23 AM
Engine: 5.0 305 tpi
RBob.
Ok, very interesting. So it could be a defective coil and or spark plug wires?I got Taylor 8mm wires. And coil looks to be original.
Old Mar 10, 2016 | 07:25 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Guessing burned plug wire or its not on all the way.
Old Mar 10, 2016 | 07:30 AM
Engine: 5.0 305 tpi
Burned plug wire could be possible,but I have those metal sleeves covering the plug wire boots. And I got them routed so they don't even come close to touching the exhaust. I could double check. But they are so hard to put them on. But these are all good checks. I'm gonna be busy once I get home.
oldsterB4C
Camaros Wanted
Mar 24, 2016 06:26 AM
musclecar70sfan
Mar 19, 2016 11:45 AM
86B4Z
Mar 16, 2016 12:10 AM
kleetis
Mar 14, 2016 07:10 AM
3gnation
Mar 3, 2016 10:11 PM
