Which valves for vortec heads?
Old Mar 11, 2016 | 08:04 AM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
I've got a spare set of heads that need to be cleaned up as well as ls6 valve springs, comp roller tip rockers and comp 787(I believe) retainers. They do need new valves though. Any suggestions? I'd like to build these up and eventually swap them onto my l31r with a better cam.
Old Mar 11, 2016 | 08:09 AM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
Re: Which valves for vortec heads?
Swirl-polished, undercut, 30* back-cut. Brand doesn't matter.
Old Mar 11, 2016 | 12:41 PM
cardo0's Avatar
Car: Fourth Gen '94 camaro
Engine: 350 Gen II
Transmission: A4
Install as large a vlv as the seats allow. Usually 2.00"/1.55".
Good luck.
Old Mar 12, 2016 | 12:29 AM
Night rider327's Avatar
Car: 1988 Camaro
I have used these in many engines. Great valves, great price
http://www.competitionproducts.com/S.../#.VuO24H0rLDc
Old Mar 12, 2016 | 07:11 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
What's your impression of the valve job on those? Is it a standard 30-45-60?
Do you ever run into a problem where the seats in the head are so beat up that these valves sit too deep after the valve job?
Personally, I'm surprised at how little seat wear I've seen on 250k Vortec heads, but I don't know if that's the norm. I haven't looked at any "Hecho en Mexico" versions yet that have gone that distance.
Old Mar 12, 2016 | 01:09 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
Are these a direct swap for vortec heads or should I have a machine shop look at my heads first?
insomniac
Brakes
Mar 9, 2016 07:08 PM
DynoDave43
Car Audio
Mar 9, 2016 02:53 PM
shugart111
Mar 9, 2016 02:44 AM
Abubaca
Mar 5, 2016 01:11 PM
3400swap
Mar 5, 2016 10:24 AM
