Prop Valve 10164112
Old Mar 9, 2016 | 02:19 PM
insomniac's Avatar
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
Prop Valve 10164112
SO can I use this prop valve http://www.flynbye.com/catalog/i172.html for a 91 with stock front disc and a swapped 9 bolt rear w/disc?
Says its for the 1 LE but i dont think they made another disc/ disc set up? Is that a better option then the stock disc/drum valve?
Old Mar 9, 2016 | 04:10 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Prop Valve 10164112
The valve is correct if the 9-bolt has PBR's (or if you swap to them).
There are three valves: disc/drum, disc/disc (Delco-Moraine), and disc/disc (performance/1LE/PBRs). All rear disc cars were equipped with the latter, 89-92. For best brake performance, I'd use the correct valve for your application.
If the 9-bolt has Delco-Moraines, however, you'll have an issue using the correct valve because it won't fit the tube nut threads on your 91.
JamesC
Old Mar 9, 2016 | 06:16 PM
insomniac's Avatar
Engine: 5.7 L98
JamesC
whats a pbr?
Old Mar 9, 2016 | 07:02 PM
JamesC's Avatar
whats a pbr?
Single piston alum calipers. If yours are iron, they're Delco-Moraines (and not terribly desirable as they often don't function very well).
JamesC
Old Mar 9, 2016 | 07:03 PM
insomniac's Avatar
Engine: 5.7 L98
JamesC
yes i got the shitty ones then... with the big *** weird counterweight on the ebrake....
Old Mar 9, 2016 | 07:08 PM
insomniac's Avatar
Engine: 5.7 L98
and yes they work horrible
evo-offer
Mar 18, 2016 11:04 AM
DynoDave43
Car Audio
Mar 9, 2016 02:53 PM
SRKLEGIN
Mar 7, 2016 06:40 PM
midias
Mar 7, 2016 12:07 PM
3400swap
Mar 5, 2016 10:24 AM
