HELP!! - Ignition Control Module
Old Dec 24, 2001 | 10:40 AM
SwitchBlade's Avatar
I have a 1988 Camaro RS 305 TBI (stock)-
About 5 months ago the ignition control module went dead, I had fuel up to the injectors but the injectors wouldn't work - so I replaced the module and it was working fine.. until now.
The ignition control module went out on me again! No biggie I can just replace it - it's not that hard but I was wondering if anyone knows why it went dead on me again just 5 months later? - I used the die-electric grease on it but not very much however i heard this is just to prevent corrosion and without it - it may shorten the life of the module - could that possibly be why it went on me again so soon?
Thanks for your help
-SB
Old Dec 24, 2001 | 10:58 AM
gruveb's Avatar
Car: 1989 IROC-1
What brand are you using?
I have had similar problems with the cheap aftermarket modules. I purchased an Accel module about 6 months ago, and it seems to be doing OK.
The others would NOT last at all! I wanted to try the MSD module, but couldn't find one at the shop.
Good luck!
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
TrevinE
Sep 14, 2015 03:20 PM
Jlanz55
Sep 6, 2015 03:05 PM
Jlanz55
Sep 6, 2015 02:35 PM
