intermittent problems advice needed
Old Apr 20, 2016 | 12:11 AM
Steelbilly's Avatar
I'm having some issues with my girlfriends 88 iroc 305 tpi it has a intermittent problem when first starting the car it will idle very low at 500 hundred rpm and if you touch the gas it dies. If you leave it alone it jumps to 1300 rpm and then finally settles down to 750 I have witnessed this a few times. The other thing I haven't witnessed she tells me she's driving down the road and h gives it th throttle and it and it doesn't gain rpm and has even died driving down the road. And is currently not throwing a code. I need some advice on where to start.
Old Apr 20, 2016 | 12:13 AM
Steelbilly's Avatar
Re: intermittent problems advice needed
Like I said intermittent we drove it all weekend with no problems and Sundays night it died on her driving home.
Old Apr 20, 2016 | 11:21 AM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
I posted a thread in the TPI "engine surges". I have been battling the same issue but mine never dies, My enigine RPM is all over the place, but not all the time. I think it is injector related. I have been running Seafoam through my fuel system. 2 cans per tank 2 tank fulls. It has not 100% cured the problem but more times than not it runs fine, which is 180 from where it used to be. I really think the injectors need to come out and be professionally cleaned and recalibrated. My car has an average of 2500 miles per year so it did a lot of sitting and sitting with gas clogs or sticks injectors.
Old Apr 20, 2016 | 12:51 PM
Steelbilly's Avatar
Maybe i'll try some fuel system cleaner. It almost seems like a sensor is wigging out to me
Old Apr 20, 2016 | 01:36 PM
edixon24's Avatar
Car: 1990 IROC
Engine: 383 Trickflow HSR
Transmission: auto
I had similar issues with idle among other multiple symptoms. Troubleshot it until I found out my ecu was bad. Tapped on it with a screwdriver handle and the car wigged out. $100 fix
Old May 14, 2016 | 01:25 PM
Johnny*G's Avatar
Car: 1987 Trans Am
Engine: 355 Edel Int, SLP, Edel heders 8PSI
Axle/Gears: 3.45 Borg Warner
Have you cleaned the Mass Air Meter? they can act up and not throw a code...
86ZRESTO
May 21, 2018 08:33 AM
IROC AND ROLL
Mar 29, 2016 09:52 AM
jakemack96
Mar 29, 2016 09:23 AM
brockerboy
Mar 29, 2016 04:15 AM
neilcase
Mar 21, 2016 10:08 PM
