parking issue
Old May 16, 2016 | 06:25 PM
rscaracas's Avatar
Car: Camaro RS 1991 305 TBI
Engine: 305 LO3
Transmission: automatic
Axle/Gears: stock
parking issue
Hello friends
I have a problem when I put the lever in park as it sometimes does not lock the box will be stretched cable problem or internal
regards
Old May 17, 2016 | 06:21 AM
Vader's Avatar
Re: parking issue
If the cable is removed and the quadrant is placed into park directly at the transmission does the parking pawl engage properly? If so, it may be a worn or misadjusted cable. If not, there may be a problem in the transmission with the linkage. Most of the mechanism can be observed by removing the transmission oil pan.
Old May 17, 2016 | 03:21 PM
rscaracas's Avatar
Engine: 305 LO3
Axle/Gears: stock
Re: parking issue
tks vader i think is cable because y feel "juego" in the lever i dont now the word in english to juego
rewards
Old May 17, 2016 | 06:26 PM
Vader's Avatar
Re: parking issue
juego en inglès es "play" o "slop" o "lash."
If the cable gets disconnected you should be able to verify that. If it is the cable, you may find in the process of disconnecting it that the anchor point or adjustments are loose.
Old May 17, 2016 | 07:21 PM
rscaracas's Avatar
Engine: 305 LO3
Axle/Gears: stock
Re: parking issue
thank you again vader
Old May 17, 2016 | 07:25 PM
rscaracas's Avatar
Engine: 305 LO3
Axle/Gears: stock
Re: parking issue
it is possible that the cable is stretched, it has grown?
Old May 17, 2016 | 08:27 PM
Vader's Avatar
Re: parking issue
It is possible the cable has stretched, and if so can be adjusted. Again, working near the transmission it should be easy to determine that.
dimented24x7
Wheels and Tires
Apr 21, 2018 07:00 PM
gbettner
Sep 8, 2016 08:26 PM
s19243h
Brakes
May 19, 2016 06:32 AM
sleprock
May 17, 2016 09:45 PM
geoffhughes1986
May 15, 2016 01:40 PM
