Replaced 3 computers and car still won't run right
Old May 26, 2016 | 10:28 PM
gators_bucs_fan's Avatar
Car: 1982 Chev Camaro
Engine: 5.7 TPI
I have an 82, but, the guy I bought the car from put a 5.7 tpi in it. Ran good for awhile. One day I went to start the car and nothing happened. Didn't hear fuel pump so I replaced that first. Still nothing. Smacked computer and car started up. Replaced it with one from the junk yard and it ran for a year then same thing happened. So i tired 1 more used one and 2 weeks later it did the same thing. So I bought a reman and car still would not start. After awhile it finally started up. I drove it down the road and it stalled out. Had to sit for awhile to get it started back up. Does this sound like an EPROM issue or something else? I can get the eprom fixed at the parts store in town, they send it on somewhere to get fixed. It costs $110. Just want to make sure that's a good start to find out what the problem is. Also noticed that just before the car would stall out, the radio would power off then come back on. Any help will be greatly appreciated.
Old May 26, 2016 | 10:34 PM
someone972's Avatar
Car: 1991 Firebird Formula
Engine: 5.7L TPI
Re: Replaced 3 computers and car still won't run right
Hmm, have you verified that all your grounds are intact and have a good connection? There's some all over but check the heads in the back of the engine. Also make sure the positive cable has good non-corroded, tightened contact at both the battery and the starter.
Old May 26, 2016 | 10:44 PM
Since the ECM doesn't control the radio, I'd rule out the ECM.
"The simplest explanation that fits all the facts is usually the right one". One corollary to that truism being, that if a proposed "explanation" doesn't fit all the facts, emphasis on ALL, it's probably NOT the right one. Which of course would illuminate why after 3 identical actions without a result, one can assume that the action in question probably isn't directed toward the actual problem.
See the popular definition of insanity: doing the same thing but expecting different results. I'm not getting the feeling that you're insane, so it's time to quit doing that and do something else instead.
I'd be checking battery cables and connections if I were working on it.
Old May 26, 2016 | 10:45 PM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
Replace the fusible links by the starter if connections are good everywhere else.
Trust me
Old May 27, 2016 | 09:41 AM
Good suggestion: the fusible links are actually part of the "battery cable" system in a way, since they are the wires that connect THE ENTIRE CAR to the battery. A broken / intermittent one of those, or a bad connection where it hooks to the solenoid post (loose nut for example) or to its big red wire, will have the same effect as a bad connection at the battery.
Old May 27, 2016 | 06:53 PM
Engine: 5.7 TPI
ok, I will have to check everything. Thanks for the help. Will update after I check it all over
Old May 27, 2016 | 07:04 PM
thtanner's Avatar
Just plan on replacing the fusible links. Don't even bother testing them, just replace them. A proper auto parts store (mom and pop place) will have it handy.
Old May 27, 2016 | 08:36 PM
Engine: 5.7 TPI
ok. I will go down to napa and pick some up
Old Jun 9, 2016 | 12:14 PM
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
I always have the rotor facing cup 1 which I can't remember if that's drivers or pass side atm since I haven't touched it in a month. I try to find tdc of cyl 1 and back it off 12* because it wants 12*btdc. Trying it at 0 doesn't help either. Anyhow drop dizzy in route wires. Cap facing 1 and try to start it
broke91firebird
Sep 2, 2019 10:02 AM
M3638
Apr 5, 2016 07:57 AM
Jared Garner
Mar 25, 2016 11:18 AM
91banditt2
Mar 23, 2016 12:11 PM
db057
Mar 14, 2016 08:53 PM
