Opinions of underdrive pulley's
Old Jun 17, 2016 | 09:50 AM
mikeyt's Avatar
Car: 92 Camaro
Axle/Gears: stock
I've got a 92rs 305 and thinking about them.
1. Do they really gain you between 8-15 hp
2. Are they worth the cost?
3. If so which ones are better than others?
Old Jun 17, 2016 | 10:17 AM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Opinions of underdrive pulley's
Is this a car for the track only , whose most running time is spent at high RPM ? Sure , sounds like a way to free up a pony or few . 15 HP is kinda optimistic , but there would be at least some gain .
Is this car driven on the street at all ? Forget them ! They will have your waterpump and alternator turning too slow at the average RPMs a street car will be doing . Tell me , ya got a Bangin' sound system in there ? If so , with how hungry Subwoofer's Amps are , why would you want any part of slowing your alternator down (crippling it's output) ?
Old Jun 17, 2016 | 10:22 AM
Abubaca's Avatar
I did a lot of reading on this subject a few years back, as well as having second hand experience with many of my fellow club members using them. ....and most ended up going back to standard.
Obviously, by design, they turn your alternator, power steering and water pump slower. ...so...you potentially lose efficiency in those areas. Some more important than others of course. ...and of course, you'll hear some people who hated dimming lights or hotter run temps, and other people seem to have no issues at all.
....and they do gain power, but again, whether or not it's noticable without being at the track or on a dyno is debatable.
....at the end of the day, my thoughts are that unless you're racing fairly seriously, where every pony counts, I'd put money and effort in other places.
Old Jun 17, 2016 | 10:36 AM
heat seeker's Avatar
Car: 89 Formula
Engine: 383 SBC/HSR
Nope, they're not.
Old Jun 17, 2016 | 10:48 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
If you buy the march power and amp kit it keeps the same ratio for driving the alternator and waterpump. It includes smaller water and alternator pulleys to spin them faster after reducing crank size
Motor will rev faster with the reduced mass. I like them. I saw about a .05 sec et gain but hard to say since weather could have changed things
Old Jun 17, 2016 | 11:40 AM
mikeyt's Avatar
Car: 92 Camaro
Axle/Gears: stock
Wow, that's good info. It's only a daily driver and the amp and subs portion of the stereo will be a Christmas present to my daughter, so I see what your saying about reducing output, however will the amp series from march would be the way I go if I do this. It's just something I saw I thought would be neat, not say it's needed but cool. Also do I have to include this in my tune info when I get my chip done?
Old Jun 17, 2016 | 11:48 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
If you add stereo, i would suggest a 140 amp alternator upgrade and def use the power/amp series pulleys with the smaller alternator pulley
I ran a stock L98 with and without the alternator pulley. Stock alt pulley and underdrive crank pulley had charging issues at idle. Once i added the smaller alt pulley from the kit, no more charging issues
Old Jun 17, 2016 | 01:47 PM
mikeyt's Avatar
Car: 92 Camaro
Axle/Gears: stock
I don't feel like buying another alternator. Will changing just the crank pulley help or is all or nothing?
Old Jun 17, 2016 | 02:02 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
It will keep stock amp rating output but its only like a 90-105 amp alternator.
I thought subs and stereos sucked down power? It may not need it i dont know how much power an amp, speakers and headunit draws
Old Jun 17, 2016 | 02:07 PM
mikeyt's Avatar
Car: 92 Camaro
Axle/Gears: stock
An extra 150-200 can be spent on something better...you're right
Old Jun 17, 2016 | 05:37 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Glad I ran across this thread! Was looking into buying a set, but my car will never see track time so I'll stay with the stock ones...
hgen81
Nov 19, 2019 01:06 AM
jac113
Jun 24, 2016 10:32 PM
kurtis72
May 30, 2016 06:15 PM
trevosaursflex
May 24, 2016 04:57 PM
