Camaro won't start
Old Jun 28, 2016 | 09:27 PM
Ben_'s Avatar
Camaro won't start
I have a 1990 iron z 305 tpi and I'm fairly new to this so bear with me on this but it was running fine, I changed the spark plugs and when I drove it home and shut it off and now it won't turn back on. It will crank but won't turn over.It starts right up with starter fluid then the rpms will fluctuate then it'll die. I've replaced the fuel filter but that's about it and I'm stumped and what the problem is. Any ideas?
Old Jun 28, 2016 | 11:25 PM
MSgt Luttrell's Avatar
Car: 1986 IROC Z28
Engine: Carburated small block 454
Transmission: Level 3 Raptor 700R4 2600 stall
Axle/Gears: Strange S60 3:73 S Trac Posi
Re: Camaro won't start
Do you have any fuel pressure?
Old Jun 28, 2016 | 11:40 PM
Queball's Avatar
Car: 92 Camaro RS
Engine: 5.0
Transmission: 700r
silly question as it may seem but did you put the filter on correctly? putting on fuel filter backwards will keep it from running. easily can be done if your stuck under a car n just had a "duh" moment. we all have em.
really just simply back tracking on what you did, make sure you didnt disconnect something n forgot to attach it etc etc.
Old Jun 29, 2016 | 04:47 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
If all you did was spark plugs, and it drove itself home, and it runs on starter fluid, then I would consider this unrelated.
Check the basics for fuel symptoms:
Fuel pressure 40-42 psi
Fuel pump priming
Injectors pulsing
also ensure that while cranking that the RPM gauge is bouncing, if it is completely still during cranking than it is likely to be your pickup coil in the distributor.
Old Jun 29, 2016 | 05:22 AM
valicswarrior's Avatar
Car: 1985 Firebird S/E
Engine: SBC 350, mild cam Vortec heads
Transmission: Rebuilt 700R4 vette servo+shift kit
verify filter is in correctly, if it is get a fuel pressure gauge (can barrow one from most auto parts stores) and test for pressure could be looking at a bad fuel pump.
86ZRESTO
May 21, 2018 08:33 AM
dhobbs
Apr 25, 2016 08:01 AM
TheJoeY88
Apr 1, 2016 03:08 PM
CamaroBlues
Apr 1, 2016 11:28 AM
IROC AND ROLL
Mar 29, 2016 09:52 AM
