Intake Question, Is this True???
Car: 99 Formula
Axle/Gears: 342
My brother was saying that on, I'm guessing a dual plane intake, I believe that's what I just got, there's a picture below. That if you cut about 1/4" down on that divider plate in the middle and remove that 1/4" section, that I would gain some low end torque. Anyone ever heard of this??
yeah, you can do that. there are a few mfr's that do that on their intakes stock. i also know a builder that takes the wall almost all the way out too. it's supposed to let the pressure/vaccume equalize on both sides of the manifold and help equalize the flow or some crap. i did it a few times and didnt notice much.
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
I would think that removing that divider plate would turn your dual plane into a single one. If I'm right then single plane intakes don't promote off idle torque as well as duals do.
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
first thing to try is a 1 inch open spacer
if hood clearance allows. If the loss of lowend comes with an appropriate increase of hi-rpm power, then its a good trade-off. The standard performer type intake will not make much hp above 5500 regardless.
If your GM motor still has the stock cam, I would not worry about it.
Yeah. Forget it. Not worth doing. If you think you want to try something like this then get a 1/2" open spacer and throw it on top first before you permanently grind away the plenum in the manifold.
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Your brother has it wrong.
If you cut out the center divider all the benefits of a dual plane
will be lost. Like smooth cruising, low and midrange torque, and gas mileage and throttle response. If you want a single plane,
go buy one. Like a Victor Jr. If you need to increase the top end power of your dual plane, put on a larger carb. Try a fully divided spacer (Edelbrock, TD etc.) to increase plenum volume. Or get one that is tuned to a higher rpm EG(Performer RPM).
Car: 99 Formula
Axle/Gears: 342
will be lost. .
will be lost. .
ambainb
Apr 25, 2016 09:21 PM
