Fuel smell after shut off / trouble starting
Hello, I appreciate any help in advance.
I am second owner of a 1992 Convertible RS with 12K original miles, yes I know I need to drive it more! I took it out twice so far this summer and after each ride upon shutting the car off I smell gas near the back end of the car. When I go to restart it takes a lot of cranks and some pumping of the gas, then she fires up. Once started she runs out strong without hesitation. The trouble is only with starting the car. Do I look to the fuel pump or other areas? I am worried about the gas smell and potential small leak. It has the original 305 throttle body set up in it. Any input would be appreciated. Thank you!
Re: Fuel smell after shut off / trouble starting
Engine: 4++,350 & 305 CIs
Do a fuel PSI check and has the fuel filter ever been changed?
86TpiTransAm
Aftermarket Product Review
Jan 31, 2001 10:19 PM
