2.8 to 5.7
Old Jul 16, 2016 | 11:13 PM
jimbo1749's Avatar
Want a title? Post!
2.8 to 5.7
I have a 87 2.8 liter Camaro and I have a 90 Cadillac 5.7 liter. Can that swap be made? Goin from throttle body to carburetor. Any help will help.
Old Jul 17, 2016 | 11:08 PM
ThirdGen1984's Avatar
Car: 1984 F41 Camaro
Engine: LC1 V6 2.8L
Transmission: 4 Speed Auto
Re: 2.8 to 5.7
I believe the swap is possible, but not sure on what all is required.
Old Jul 18, 2016 | 06:00 PM
hdis2002's Avatar
Car: 87 IROC Z
Engine: 5.7
Re: 2.8 to 5.7
It's definitely possible. BUT. The 5.7 will fit just fine, may have to change the motor mounts. Other considerations: transmission, drive shaft, fuel pump, fuel lines, vacuum for brake booster. Many more things, but just a few things off the top of my head. Try a search for this conversion. I guarantee someone has written a post about it.
Old Jul 18, 2016 | 07:46 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 2.8 to 5.7
Transmission should have a different bellhousing pattern but the driveshaft length doesn't change so the driveshaft doesn't need to be replaced.
It would be a lot easier to find a third gen donor car that has/had a V8 to get everything required for the swap.
Old Jul 19, 2016 | 06:27 AM
Re: 2.8 to 5.7
Forget "Cadillac". That's just the stickers on the sheet metal.
It's the same as any other small block Chevrolet swap. (it's a Chevy 350)
Visit the Engine Swap forum and read all the stickies and the millions of posts from other people about the exact same swap before asking questions; there's a VAST amount of information sitting there waiting for you already. Much better to learn what people have already documented for you, than the way "some" people (mostly the real "entitled" ones) DEMAND to be spoon-fed.
MarkF
Apr 30, 2016 12:06 PM
Jan1980
Apr 3, 2016 12:28 PM
evo-offer
Apr 2, 2016 04:42 PM
Cm87pta
Aftermarket Product Review
Aug 13, 2001 12:38 AM
dlp
Jan 29, 2001 06:49 PM
