Nut in timing chain cover
Old Jul 17, 2016 | 09:11 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
As crazy as this sounds I dropped the set screw off a poly lock into the intake valley and it went down the timing cover hole. I had the rest plugged. Any way I heard it fall down fairly far.
I plan on pulling the cover but I wanted to know if there was any way it could have made it into the pan? I would be happy to drain the oil and see if it comes out first before starting to take all the crap off to pull the cover.
Old Jul 17, 2016 | 09:15 PM
Re: Nut in timing chain cover
More than likely, yes.
Absitively posolutely, ... no.
I dropped a lifter one time... exited out the pan in a beautiful .843" hole... musta landed on the pan baffle and the crank hit it... no other damage.
Old Jul 18, 2016 | 11:06 AM
midias's Avatar
Thanks, I have seen some impressive things make their way to the pan including big chunks of valve springs. I will rotate the engine by hand a few times and check the pan by draining it
Old Jul 18, 2016 | 11:14 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
you might try dragging a relatively strong magnet from the cover down across to the drain plug area. kinda walk it to there. might get lucky?
Old Jul 18, 2016 | 11:31 AM
midias's Avatar
Yes I will give that a try. Still impressed by my ability to give my self more work.
BG1959
Jul 20, 2016 02:22 PM
wgripp
Apr 9, 2016 11:46 AM
jjjosh
Apr 7, 2016 10:38 AM
chllnqtp99
Mar 16, 2016 08:03 PM
Scorched1984
Mar 13, 2016 10:10 AM
