Ticking Engine
Old Jul 18, 2016 | 12:49 PM
KingHD's Avatar
Car: 1987 Camaro
Engine: 350 HO 360whp
Transmission: Borg-Warner T5
Ticking Engine
This engine is a brand new 350 just a year old and with only 300 miles on it. Yesterday i decided to check how it was running and heard a rapid ticking by the alternator and would like some ideas from you guys that are more experienced with this than iam. Im just hoping it needs motor flush and nothing major.
Old Jul 21, 2016 | 04:34 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: Ticking Engine
Ticking could be either valve out of adjustment or a small exhaust leak at the manifold. If you have headers try snugging up the mounting bolts.
What kind of cam are you running?
Old Jul 21, 2016 | 07:30 AM
Re: Ticking Engine
Doesn't need "motor flush" unless you put ALOT of ... something that doesn't belong ... in it while building it.
Loosen the belt and see if it's an accessory.
Above advice is good: those are 2 of the next most likely things.
Adjust the valves with the engine running.
If it ticks only just slightly when idling but MUCH louder when accelerating, it's a compression or exhaust leak. Pull the spark plugs and put dielectric grease on the threads and put them back in making sure they're tight: if you see brown stuff on the threads you've been having a leak there.
Old Jul 21, 2016 | 11:35 AM
KingHD's Avatar
Car: 1987 Camaro
Re: Ticking Engine
Hydraulic Roller its the stock cam im going to upgrade it once it gets 1,000 miles.
bradberryeric
Apr 27, 2016 09:26 AM
hotrodaj
Apr 25, 2016 02:33 PM
dmccain
Apr 23, 2016 12:49 PM
802maro
Apr 22, 2016 03:20 PM
racerkilla
Exterior Parts for Sale
Apr 20, 2016 07:21 AM
