Intake bolt torque specs.
Old Jul 18, 2016 | 07:40 PM
Flip33's Avatar
Car: 1933 Ford Sedan, 1934 Ford Pickup
Engine: 350 Chevy
Transmission: 700 r 4
Am installing an aluminum intake on L-31 (vortec heads) and am wondering what the bolts should be torqued to. Thank you
Old Jul 18, 2016 | 07:47 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Intake bolt torque specs.
Standard torque works just fine. A 3/8" bolt is around 38-45 pounds.
Old Jul 19, 2016 | 08:25 AM
Flip33's Avatar
Engine: 350 Chevy
Thanks for the information. The reason for asking is I believe the stock vortec intake is torqued to 12-15 lbs. I wasn't sure if this was because of the gasket used or the intake itself and if using a more standard aluminum manifold would allow a more traditional torque amount. Thanks again.
Old Jul 20, 2016 | 01:06 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
I think votec manifolds use 5/16 bolts a total of 8 and are 15-20 ftlbs. ARP says 24 ftlbs for their bolt kit
arp-bolts.com/kits/instructions.php?RecordID=2245
Old Jul 20, 2016 | 01:20 PM
Flip33's Avatar
Engine: 350 Chevy
Midias - Thanks so much for the info. Actually the bolts are 8mm but about the same torque amounts. Lot of different information some concerning the type of gasket used. Mine are Fel-Pro so going to also give them a call before I install. Again Thanks
Flip
Old Jul 20, 2016 | 01:39 PM
midias's Avatar
Flip
8mm should be about the same as 5/16, best of luck. I used 20 ftlbs on my edelbrock vortec intake with felpro 1255 gaskets no issues for years.
Old Jul 20, 2016 | 06:35 PM
AlkyIROC's Avatar
Car: 87 IROC L98
20 ftlbs on an 8mm bolt is just fine. I think standard torque is 18-24 for 8mm.
BuiltZ28
Oct 13, 2017 12:02 PM
Golfvette
Aug 9, 2016 01:39 PM
CoryCDS
May 5, 2016 02:36 PM
haro_is_king
Apr 30, 2016 10:33 PM
Gran Torino
Apr 26, 2016 08:13 AM
