86 IROC won't start
Old Aug 13, 2016 | 12:51 PM
5 speed's Avatar
Car: 1986 IROC
Engine: 60 over 350
Axle/Gears: stock..2:73
86 IROC won't start
Came home from running errands, shut it off, went out about an hour later and it won't start..
There is nothing when you turn the key. The needle on the heat gauge tops out when I turn the key all the way which I never noticed it doing before.
I tried jumping the solenoid and it started...so it's something electrical in the ignition system.
The connections on the starter look clean, no corrosion.
Battery is fully charged but I tried boosting it to eliminate that possibility and still won't start.
Every since I bought the car every now and then it would do this but if I let the clutch out and depressed it again, the car would start.
I assumed the safety switch was out of adjustment and never bothered looking into it.
Well..the switch has been bypassed by a previous owner, so that isn't the cause.
I just got done replacing the ignition switch (not the cylinder)and still nothing.
I haven't traced the wire from the solenoid back yet but on what I did look at I didn't see a fuseable link.
Anyone have any suggestions?
The car isn't fuel injected so there is no computer.
Old Aug 30, 2016 | 02:44 PM
5 speed's Avatar
Car: 1986 IROC
Engine: 60 over 350
Re: 86 IROC won't start
bueller....bueller???
Old Aug 30, 2016 | 07:40 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Sounds like you're going to find out what has power and what doesn't. Here's your diagram http://austinthirdgen.org/mkportal/m..._continued.gif
Old Sep 1, 2016 | 06:47 PM
5 speed's Avatar
Car: 1986 IROC
Engine: 60 over 350
I think I have it narrowed down to the ignition switch...which was the first thing I replaced. lol
I found a relay spliced into the wiring harness for the neutral safety switch which I'm assuming was part of the anti theft system.
I got rid of that..which didn't fix the problem.
There is power on the "firewall" side of the 3 fusable links coming from the starter so it's losing power somewhere between there and the purple wire...
Old Sep 1, 2016 | 07:27 PM
Is there power at the yellow where the clutch switch used to be?
Old Sep 16, 2016 | 11:53 AM
5 speed's Avatar
Car: 1986 IROC
Engine: 60 over 350
No there wasn't..and it was the ignition switch. I didn't have it adjusted right....
THIRDGEN87
Interior Parts Wanted
Aug 24, 2023 01:01 PM
Derbicus
Mar 27, 2016 04:11 PM
mclenty0
Mar 20, 2016 06:50 AM
That Sky Guy
Mar 15, 2016 07:40 AM
