'90 RS 3.1 won't start
Old Sep 3, 2016 | 01:18 PM
Yfelton06's Avatar
Need help figuring out why our 1990 camaro wont start, we changed the fuel pump & fuel filter, timing chain, new battery. It is trying to turn over, it has fuel pressure and spark. Any one got any ideas?
Old Sep 3, 2016 | 02:28 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: '90 RS 3.1 won't start
If the stock ECM Multec injectors are still in the engine, that is why it won't start. Squirt a little fuel or starting fluid into the TB and see if it then starts.
RBob.
Old Sep 3, 2016 | 04:39 PM
Yfelton06's Avatar
It's tune port, tried starter fluid. Still not starting. we did find a lot of carbon build up tho? Not sure if that has anything to do with it not starting tho?
Old Sep 4, 2016 | 08:17 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
It is MPFI, the TPI systems are on the 8 cylinder 3rd gen cars.
Did the engine run before the above was changed? With swapping out the timing chain a compression test would be helpful. It would show whether the crank/cam alignment is correct.
RBob.
racing28x
Members Camaros
Mar 16, 2017 02:55 PM
mthibode
Apr 12, 2016 07:04 AM
Camarokid01
Aftermarket Product Review
Mar 18, 2001 02:26 PM
firebird305
Dec 6, 2000 11:49 PM
