Msd blaster ss coil problem
Old Sep 3, 2016 | 01:41 PM
L6969's Avatar
I'm converting to external coil no box, stock dizzy with msd modified hei dust cap and blaster ss coil, here's what I've done as per the instructions but it won't start I'm probably missing something obvious but I can't seem to figure it out...
Disconnect 3 pin and single pink pin harness from cap
Connect supplied pink "y" wire to pink in 3 pin harness and single pink pin, connect to positive on coil
Connect brown supplied wire to brown in 3 pin harness connect brown to negative on coil
Install msd modified dust cap and connect coil wire to dust cap.
Won't start?
Went back to the internal accel hei coil set up I had before no problems starting.
stegal
Apr 21, 2016 10:25 PM
efiguy
Apr 4, 2016 06:34 AM
Lurbie
Mar 21, 2016 08:57 PM
Steve89GTA
Aftermarket Product Review
Sep 24, 2000 09:55 AM
