Oil Pressure?
Old Sep 7, 2016 | 11:53 AM
ClaudeMaryK's Avatar
Oil Pressure?
I have a 1992 LT1 with 1994 heads with the coded digital gauges.
When I turn on the ignition {not starting yet} the oil pressure gauge reads
99lbs.When I start the engine it goes to 70-80lbs. When it warms up to
operating temperture it climbs up to 99lbs again. Seems like oil pressure should drop a little when warmed up. If the oil pressure gauge is okay what else
could be the problem? Thank You
Old Sep 7, 2016 | 11:58 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Oil Pressure?
Something is wrong with your gauge or sender. 99lbs is super high and impossible with the engine not running.
Jlp06
Fabrication
73
Feb 11, 2019 09:54 AM
AdjustablJustin
Sep 14, 2016 10:10 AM
diablizzard
Sep 13, 2016 07:37 AM
battman
Sep 7, 2016 08:19 AM
Yfelton06
Sep 4, 2016 08:17 AM
