Serpentine belt jumps off crank pulley
Old Oct 2, 2016 | 07:00 PM
RedneckNo4's Avatar
Car: Trans am
Engine: 78 350
Axle/Gears: 9 bolt 3.27
I had all of the serpentine parts from a v8 swapped s-10 so I decided to put them on my TA when I gave up fixing rust. Anyways, everything looks fine and all of the pulleys are fully engaged except the belt comes out of the groves on the crank pulley. It still spins everything but only half the belt is on.
I tried a new tensioner and a new belt but it still falls off. The brackets are from an 89 TA. I'm out of ideas on it, but I don't want to drive around with the belt only half on the crank pulley. I got new AC lines and a compressor and already modified the wires so I'd rather not go back to V belts.
Old Oct 2, 2016 | 07:38 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Serpentine belt jumps off crank pulley
Sounds like you have a pulley alignment problem.
Old Oct 2, 2016 | 07:45 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Do you have the correct balancer and pulley? Is the balancer fully seated?
Old Oct 3, 2016 | 01:06 AM
Twin_Turbo's Avatar
get a laser pointer to align the belts, put it square on the accessory pulleys and check ifn they are aiming dead straight at the crank pulley. With different damper thicknesses you can run into problems. I've had to shim the brackets to align it properly on some of my builds.
grnmachine
Sep 29, 2016 03:53 PM
mynameisfrank89
Sep 19, 2016 10:49 AM
Warrior
Nov 15, 2002 01:40 PM
Ward
Apr 11, 2002 04:24 AM
88FiretruckGTA
Jul 17, 2001 09:08 PM
