high rpms at highway speeds
Old Nov 21, 2016 | 07:40 PM
wisemanz28's Avatar
My 89 Camaro runs at high rpms at highway speeds. I'm sure the car is in overdrive. I checked the tach, thats accurate, changed filter and put in new tranny fluid, Can you guys suggest anything else ?
Old Nov 21, 2016 | 09:52 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: high rpms at highway speeds
How high is high?
What's the engine RPM at "X" road speed?
Old Nov 21, 2016 | 10:46 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Also tire size and diff gear ratio
Old Nov 22, 2016 | 05:17 PM
wisemanz28's Avatar
This all happened when my radiator blew and the engine got hot. The repairs were done but afterwards I noticed that at 60 mph I am at 3300 rpm.
Old Nov 22, 2016 | 06:20 PM
AlkyIROC's Avatar
Car: 87 IROC L98
How do you know the tach is accurate?
You can check the accuracy of the speedo with a GPS speed app with your phone.
I had a 91 454SS pickup truck. OD transmission, 4.10 gears and 28" tall tires and it was close to 3000 rpm at 60 mph.
Old Nov 22, 2016 | 07:25 PM
wisemanz28's Avatar
checked the tach with a aftermarket tach, both read the same exact rpms at highway and regular driving speeds. The car always ran 2000 rpm at 60 before the radiator blew
Old Nov 22, 2016 | 07:29 PM
zed-028's Avatar
Car: 1987 Z28 Camaro
Engine: 305 LG4 4bbl
torque convertor locking up? sounds like its not locking at high speeds. even so that still seems pretty damn high
Old Nov 22, 2016 | 07:45 PM
wisemanz28's Avatar
I manually shifted the car and it went into all gears perfectly including o.d. , I'm leaning towards the tcc solenoid being bad
Old Nov 22, 2016 | 07:47 PM
zed-028's Avatar
if you get under there, apply 12v to one of the lines on the tcc solenoid and see if it clicks.
Old Nov 22, 2016 | 08:06 PM
wisemanz28's Avatar
Thanks Zed , I'm kind of a novice when working on transmissions, where would thee TCC solenoid wires located ?
Old Nov 22, 2016 | 08:44 PM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
Math says 2283
Old Nov 22, 2016 | 08:49 PM
cosmick's Avatar
If it was just the converter not locking, that would add 200 RPM at a steady cruise, not 1300.
No way this thing is shifting to OD, no matter where the shifter is placed.
2000 at 60 should be a 3.42 if 700R-4, so that should be 3100 at 60 in third with the converter unlocked in third. 2000/0.696=2900+200 slip.
If this is a T5 with the 0.63:1 fifth, then the math works with a 3.73 or 3.91 axle, depending on tire size.
Old Nov 22, 2016 | 10:37 PM
zed-028's Avatar
yeah thats why i said it still seems pretty damn high.
i think with my 305 with the 700r4 at 60mph (somewhere near ~100km/h here in aus) its in the mid 2000's in 4th without lockup
Old Nov 28, 2016 | 06:10 PM
wisemanz28's Avatar
Just took my 89 Camaro out for a drive, at a steady speed while in od I tapped the brakes and the rpms went up 200 to 300 rpms, that tells me my torque converter is working so I can rule that out
