Battery hold down bracket
Old Jan 6, 2017 | 08:58 AM
podiatra's Avatar
Car: 1986 Camaro IROC-Z
Engine: 350 swap
Transmission: manual
HI,
I am trying to find out what is the correct battery hold down bracket retainer for the battery. My battery is sitting on the tray only. I don't see any holes, nor a way to use an universal kit.
Any suggestions appreciated.
Old Jan 6, 2017 | 09:27 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Battery hold down bracket
It looks like this:
http://www.rockauto.com/en/catalog/c...le.com+URL+%2F
It uses a bolt with a captive washer.
Old Jan 6, 2017 | 09:32 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
My factory battery had a little rubber hold down that went on the back side. This is it
http://shop.advanceautoparts.com/p/d...DdIaAo508P8HAQ
After I changed batteries I ended up making a new one. All of this was because the previous owner changed the cables to a new style
Attached Thumbnails Battery hold down bracket-battery_holder_1.jpg   Battery hold down bracket-battery_holder_2.jpg
Old Jan 6, 2017 | 09:51 AM
podiatra's Avatar
Engine: 350 swap
so the pictures attached is the new one you make right?
Old Jan 6, 2017 | 09:52 AM
midias's Avatar
Yes the pictures is the new one I made. The link is the factory piece.
Old Jan 6, 2017 | 10:01 AM
podiatra's Avatar
Engine: 350 swap
perfect! Thank you both.
Old Jan 6, 2017 | 10:07 AM
gt4373's Avatar
Transmission: 5-Speed Manual
Old Jan 6, 2017 | 10:11 AM
midias's Avatar
I believe the bolt hole is a standard M8 maybe M8 x 1.25.
I just welded a bolt into a piece of square stock and drilled a hole in the side for the hold down hook.
Old Jan 6, 2017 | 10:50 AM
podiatra's Avatar
Engine: 350 swap
got it.very creative
