firing order 2000 Chevy 305 in boat
Old Jun 1, 2017 | 06:11 PM
soulman7777's Avatar
Want a title? Post!
Is there any benefit to switch firing order of 18436572 on my 305 Chevy in my boat (year 2000) to this alternate of 18726543; or is it not doable without changing camshaft, etc?
Old Jun 1, 2017 | 06:33 PM
Drew's Avatar
Re: firing order 2000 Chevy 305 in boat
You're on the wrong forum unless your "boat" is a Camaro or Firebird built between 1982-1992.
Old Jun 2, 2017 | 06:23 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
No benefit. And yes, it would require changing the camshaft.
Old Jun 3, 2017 | 11:10 AM
Vader's Avatar
I have a few vehicles with SBCs which have been called "boats" so there is a thin connecting line here...
The only measurable benefit to changing the firing order in a marine installation is to change to 12756348, install that engine in the right side of the transom to counteract the "normal" engine on the left side of the transom.
Old Jun 3, 2017 | 12:42 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I thought the 307 was a boat, not the 305.
If you do have the dual engines, they're usually BBC.
Old Jun 3, 2017 | 12:56 PM
Ja85z28's Avatar
Axle/Gears: 4:10
18436572 don't change the firing order.....
Old Jun 3, 2017 | 04:58 PM
Drew's Avatar
No, No, No. It's boat anchor. And it applies to the 267, 305, and 307.
zya5point0
Jun 4, 2017 07:51 AM
84TransAm305
Theoretical and Street Racing
59
Feb 24, 2009 09:28 PM
jonb
Apr 20, 2005 12:15 PM
cobrakiller1989
Oct 20, 2000 10:43 AM
