New CV joints
New CV joints
My car is making a clicking noise when I turn, which obvisouly means my cv joints are gone, usualy I have this done but since I am so short on cash I might have to do it myself, how hard is it and what exactly do I do to change them
Car: C1500
If you are talking about your Bird it doesn't have CV joints. Tell us a little more about this noise and maybe we can figure out what it is.
Car: 4
Engine: 6
Transmission: 5
Actually I put some in my car once, but I installed them improperly... into the back seat floorboard. They were incapable of performing to their fullest potential there however, so I put them into some other car.
Car: Death Mobile
Engine: 666 c.i.
Yeah, my wheels are making clicking noises, its wheel bearing time I thought we had cv joints, my mistake but anyways how hard is it to change these? people asked for what kind of car I had, but it was in my sig I dont understand
Car: 89 IrocZ
Engine: L98-ish
Well, beings that you asked about CV joints, many probably thought you were talking about a different vehicle than your F-Body.
As mentioned before, could be wheel bearings. Could also be brake HW rattling.
Best thing to do is lift the frontend up and shake a few things and see if you can find where it's coming from.
Its def my ball bearings, when I turn the wheel it makes a very distinct clicking noise, having experience with cars I can diagnois problems I just in the past let other people fix them which I can not to now, it was my mistake I didnt know if our cars had cv joints or bearings, so how would you replace them? the bearings?
Car: 89 IrocZ
Engine: L98-ish
You'll need to remove the wheels,
Pull the discbrake HW off, wire it up so that the caliper are not hannging on the brake lines.
Pull the dust cover. Pull the cotter pin on the castle nut, and unscrew the nut.
Pull the rotor assy. off. The outer bearing will fall out into your hand.
Pry out the old seal off the inside and the inner portion of the inner bearing will fall out.
Lay the rotor with the wheel studs up, supported off the bench a few inches and take a drift punch and knock the outer race for the inner bearing out.
Knock in the new outer race.
Pack the bearings in grease, install the inner bearing and the inner seal and slide it over the spindle.
Put in the outer bearing assy and install the castle nut.
Seat the nut to 20-25 ft/lbs, then back it off until the first hole lines up for the cotter pin (use new cotter pins).
Intsall the dust cover, brake HW.
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
you might need outer tie rods. Mine were clicking bad when I turned, so I bought Moog tie rods and this took care of the problem.
sjorgens
Oct 1, 2015 07:54 PM
bubbaz28
Sep 18, 2015 02:09 PM
