1401544 engine number
Old Jul 1, 2017 | 03:03 AM
legend427's Avatar
Want a title? Post!
Hi Guy's,
I hope someone can help me, I'm in the UK & have bought a 454 engine with the above casting number which has had the engine number ground off & replaced with a incorrect engine number by a previous owner or builder
I need to know what series of engine numbers this block would have had before August 1975 as I need to show a pre August 1975 engine number to be exempt from emissions testing
Many thanks in advance Tony
Old Jul 2, 2017 | 12:44 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: 1401544 engine number
If the partial vin and date code from the pad above the timing cover on the passenger side are gone it is likely you'll never find out. I believe that block number was mostly used in later model vehicles so it's more likely to be post 75. I'm not sure on UK rules but how are they going to prove it's pre or post 75 anyway? How that would affect emissions is beyond me but I also don't make the rules. Good luck in your project.
Old Jul 2, 2017 | 09:12 PM
NoEmissions84TA's Avatar
Searching this casting number on google, in various sites says:
* 14015445...454.......78-90...2 or 4 bolt
* 1401544 1975-87 454 4.250 4 bolt mains (casting number may also be 14015445)
* 73-84
454 BLOCK ID # 14015445
VIN CODE "L,S,W,Z"
HEAD ID # 336781, 346236, 353049, 6272292
Notes: Carb, 10-35 series, w/o H5D emissions
85-90
VIN CODE "W,Z"
HEAD ID # 14081045, 14092360, 10052902
Notes: Carb, 10-35 series w or w/o H5D emissions
Just doing a little research, which with info this dated I’m sure some of the info could be mistaken, but using the numbers you provided this is what I came up with.
Block: 14015445 – 78 to 90, 2 or 4 bolt mains
Heads: 14081045 – 78 to 87, Open Chamber 454
Intake Manifold – GM 454, Peanut Port Cast Iron, Quadrajet
To nail down the application and horsepower rating you will need to identify the Engine Suffix Code, which is stamped on a block pad located immediately forward of the right hand or passenger side cylinder head. The entire engine code contains the assembly plant, month and day.
While there could have been some swapping going on with an engine this old, if it is original you can sort of narrow it down to at least the years the heads were available.
1978 Truck Engine Suffix Codes: TRF, TRH, TRK, TRL, TRM, TRY, TSB, TSF, TSH, TSJ, TSS, TST = 250hp, Engine Code LF-8 VIN S, 20, 30
1979 Truck Engine Suffix Codes: AUA, AUB = 245hp, Engine Code L-42 VIN S, 70
1980 Truck Engine Suffix Code: TRR, TRS, TRU, TRZ = 205hp, Engine Code LF-8 VIN S, 10, 20, 30
1980 Truck Engine Suffix Code: TRT, TRW, TRX = 210hp, Engine Code LF-8 VIN S, 20, 30
1981 Truck Engine Suffix Code: TRK, TRL, UCA, UCB, UCD = 210hp, Engine Code LE-8 VIN W, AR, 20, 30
1982 Truck Engine Suffix Code: TKA, TKC, TKD, TKF, TKH = 210hp, Engine Code LE-8 VIN W, 20, 30
1983 Truck Engine Suffix Code: UBA, UBB, UBC, UBD, UBF, UBH = 230hp, Engine Code LE-8 VIN W, 20, 30
1984 Truck Engine Suffix Code: ??????
1985 Truck Engine Suffix Code: AKA, AKB, AKC, AKD, AKF, AKJ, AKK, AKM, AKN, AKR = 240hp, Engine Code LE-8 VIN W, 20, 30
Additional 1985 Truck Engine Suffix Code: TZB, TZC, TZD, TZF, TZG, TZH, TZJ, TZK, TZL, TZM = 240hp, Engine Code LE-8 VIN W, 20, 30
1986 Truck Engine Code: AKS, AKT, AKU, AKW, AKX, AKY, AKZ, ALA, ALB, ALC, ALD, ALH = 240hp, Engine Code LE-8 VIN W, 20, 30
1987 Truck Engine Code: ALK, ALS, ALX, ALY = 230hp, Engine Code L-19 TBI VIN N, 20, 30
PurelyPMD
Feb 15, 2026 11:00 PM
gcj280
Apr 25, 2017 04:43 PM
rocn7roc
Sep 24, 2016 09:21 AM
86NiteRider
Sep 21, 2016 08:22 PM
Ming
Sep 21, 2016 12:43 PM
