Check engine light
Old Jul 21, 2017 | 10:49 AM
randallp504's Avatar
Car: 1983 Camaro Z/28
Engine: 305 HO
Transmission: 700r-4
Axle/Gears: stock
Check engine light
I have a 1983 Camaro z28 lg4 I just installed headers on. The check engine light is on and I'm almost positive it's o2 sensor but when I put the key in on position (engine off) jump the top right two terminals with paper clip it doesnt go into the mode where it flashes. I tried paper clip, thick and thin, stripped a wire, stripped speaker wire etc. I put it in, wiggled, sprayed a little wd40. Nothing. Any info will help. Randy
Old Jul 22, 2017 | 03:07 PM
Re: Check engine light
Did you put an O2 sensor back in? If not, start there before even messing with reading codes. Fix what you already know you effed up before attempting to troubleshoot any further.
Old Jul 23, 2017 | 08:05 AM
Engine: 305 HO
Axle/Gears: stock
thanks man, going through it today.
86FyrBrd
Convertibles
Nov 1, 2016 07:50 PM
johng1
Sep 18, 2016 06:07 PM
theformula
Aftermarket Product Review
Dec 6, 2000 12:12 PM
theformula
Nov 18, 2000 08:45 PM
