What's this connector?
Old Jul 24, 2017 | 07:05 AM
rottweiler68's Avatar
Car: '89 Iroc
Engine: 383 TPI
Transmission: Built 700R4
Axle/Gears: 9 Bolt - 3.45
Found this hanging, appears to be broken off. It's bottom of passenger side near rear motor mount on '89 5.7
Old Jul 24, 2017 | 07:52 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: What's this connector?
secondary fan switch harness. It goes up between cyl 6 and 8 in the head.
Old Jul 24, 2017 | 08:11 AM
Car: '89 Iroc
Engine: 383 TPI
Thanks, going to try and track that part number down.
Old Jul 24, 2017 | 10:15 AM
RunawayRadio's Avatar
Car: 1987 GTA, Digital Dash
Engine: L98 TPI
Transmission: 1994 LT1 T56
Axle/Gears: 9 bolt, 3.27
Here you go:
https://www.rockauto.com/en/moreinfo...251414&jsn=506
Old Jul 24, 2017 | 10:17 AM
Car: '89 Iroc
Engine: 383 TPI
Originally Posted by RunawayRadio
Awesome, thanks so much! Is this the same part number used for the knock sensor connector as well? I see it referenced as such elsewhere.
Old Jul 24, 2017 | 10:27 AM
Car: '89 Iroc
Engine: 383 TPI
And another dumb follow up question, sorry new to much of this, what is the connector to the right of the dangling fan harness wire that is connected properly in the pic?
Old Jul 24, 2017 | 10:45 AM
Ghettobird52's Avatar
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
if thats the 'secondary fan switch' whats the first....?
Old Jul 24, 2017 | 11:00 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Knock sensor.
Old Jul 24, 2017 | 11:01 AM
Car: '89 Iroc
Engine: 383 TPI
Originally Posted by ploegi
Knock sensor.
Thank you!
Old Jul 24, 2017 | 11:14 AM
TTOP350's Avatar
ECM runs the primary fan from the cts info.
Since this is a 89 350 car it will have 2 fans, this switch (and A/C psi switch) run the secondary fan.
Old Jul 24, 2017 | 11:19 AM
Car: '89 Iroc
Engine: 383 TPI
I already have the 180* thermostat in so was thinking about going with the Hypertech 4028 switch to run a bit cooler. Does sound correct?
Old Jul 24, 2017 | 11:23 AM
TTOP350's Avatar
This may work as well
https://www.thirdgen.org/forums/engi...itch-part.html
Old Jul 24, 2017 | 07:36 PM
Ok so on the single fan setups they just work off the coolant head switch right?
Old Jul 25, 2017 | 08:03 AM
TTOP350's Avatar
I'm not well versed in single fan setups
Old Jul 25, 2017 | 06:58 PM
Car: '89 Iroc
Engine: 383 TPI
Does anyone have an actual pic of this sensor location that would be the same the '89 350? I though it was between plugs 6 and 8, but can not find it for the life of me. I have found the knock sensor from below, but should I be able to see the this fan sensor as well from the top or bottom?
Old Jul 25, 2017 | 07:06 PM
If you still have the complete ac box and heater hosing along with smog equipment all intact, it can be pretty hard to see it from up top. But its right there on the head between 6&8. The electrical connector might be snapped throwing you off.
https://www.thirdgen.org/forums/cool...an-switch.html see thread for pic.
Old Jul 25, 2017 | 07:08 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Old Jul 25, 2017 | 07:41 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
It's in the same spot(with the head turned around for the other side) as the sensor for the temp gauge on the driver side
Old Jul 25, 2017 | 08:09 PM
Car: '89 Iroc
Engine: 383 TPI
Crazy! I must be missing something it simply as Ghettobird alluded too because of being broken off. But I thought this secondary was at the rear of the head by 6 & 8, my gauge temp sensor is at the front of the drivers side, between 1 and 3.
Old Jul 25, 2017 | 08:36 PM
Car: '89 Iroc
Engine: 383 TPI
I also found posts with some accessing it from the underside. "This little switch is located in a hard-to-reach location on this Third-Generation Camaro. In other vehicles it may be easily accessible. The sensor is located on the passenger side of the engine, just below the heat shield connected to the block."
Time for a break
Old Jul 25, 2017 | 08:48 PM
ok wow yeah that looks like the location, but that looks like someone just plugged it?
Old Jul 25, 2017 | 08:49 PM
Car: '89 Iroc
Engine: 383 TPI
Sorry was editing that post with picture, but yes you are right, they probably got tired of losing coolant and plugged it. That's why i'm stumped lol.
Old Jul 26, 2017 | 08:59 AM
TTOP350's Avatar
Looks like factory it could be factory paint down in the plug, your car does have dual fans right? Or its just been plugged due to leak, breakage or during a rebuild. Either way, if you have dual fans, put the switch in that spot.
Old Jul 26, 2017 | 09:16 AM
Car: '89 Iroc
Engine: 383 TPI
Yes I do have the dual fans so will attempt to unscrew whatever it is that is in there.
Old Jul 26, 2017 | 09:23 AM
Car: '89 Iroc
Engine: 383 TPI
Is there a simple way to tap the second fan into the first (not sure if that's the term) but so that the second fan would run whenever the primary ran? Can't hurt to have this type of setup can it?
