what did you do to your thirdgen today?
Old Nov 14, 2021 | 08:40 AM
  #1601
Carlos89's Avatar
Car: 1986 Trans Am
Engine: 5.0 LG4 4BBL
Transmission: T5 5-Speed
Re: what did you do to your thirdgen today?
Well done sir.
Originally Posted by 1986BANDIT
i finally manned up and threw on the aero-wing...goodbye giant bookshelf heritage camaro wing,hello aero.
Old Nov 14, 2021 | 08:56 AM
  #1602
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
You certainly got all of the use out of this piece.
Old Nov 30, 2021 | 11:12 PM
  #1603
rearview's Avatar
Car: 1990 LS6 Camaro
Engine: LS6 with a cam basically
Axle/Gears: 4th gen 3.42 rear
I removed the brake booster and master cylinder. I'm putting 4th gen parts in (including an LS1 eventually)
Old Dec 5, 2021 | 11:16 PM
  #1604
Moonlight137's Avatar
Car: 1992 RS
Engine: L03 / MSD / 2½" "hacksaw" catback
Transmission: 4L60
I built a hatch release switch out of two broken ones.
This one came in my 92. Someone must have tried to remove it by prying. Third time's the charm, right?
It was also so brittle, I cracked it apart trying to unplug the wires.
This one came from an 88-ish in a junkyard...
...and it was real grubby.
The switch "slider" goes in first, with a spring above it to return it to "Off" when you let go.
Then the little copper plate fits over the two springs to make the connection. Note that the circuit board has to be oriented so that only two of the four contacts are touching the copper plate.
Then the circuit board snaps in. Then when you push the switch, all four copper contacts touch the copper plate. (The switch is turned around upside-down from the previous pic.)
The final answer.
You might be able to see that the "trigger" part doesn't quite lay flush on the surface of the switch body. That's because I didn't disassemble it carefully enough, and one of the two clips broke off to snap it in place. It works, though, so maybe I'll 3D-print another one someday.
Old Dec 14, 2021 | 02:47 PM
  #1605
Punk's Avatar
Car: 89 IROC convertible
Engine: LB9
Last night I ground part of the flange off the right front strut where it was touching the rim after I got the front aligned. Also found and reconnected the wire to the sender for the temp gauge. I recently dragged this car out of a 10 year storage, and I'm fixing it to daily in dry weather.
Other stuff I've done in the last few months.
Added a ported the Hiflow base, and plenum.
Added AS&M runners.
Added L98 type cam new chain & gears.
New tie rods, idler arm, drag link.
New Michelins on the back. Fronts are back ordered.
LED instrument lights.
New battery.
Changed out all the sensors.
Took off some of the A.I.R. stuff
Couple of oil changes.
Started stripping and working up for paint.
I've been driving it a lot, but this morning it wouldn't hit a damn lick. I'm afraid it's going to be the fuel pump.
Black 89 IROC convertible
original LB9/auto, now T-5
3.42 rear
Suspension mods
Old Jan 8, 2022 | 07:10 AM
  #1606
SbFormula's Avatar
Car: '18 Chev Camaro SS 1LE
Engine: LT1 6.2L
Axle/Gears: 3.91
Door refurbished. New weatherstrip, dynamat, clean-up, window adjusted, panel fixed and cleaned. Shuts and sounds like new.
Old Jan 29, 2022 | 05:18 PM
  #1607
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re-did my e-brake handle cause the first time i put the stitching on the underside! Still gotta trim it.
Old Jan 30, 2022 | 07:31 PM
  #1608
theraymondguy's Avatar
Finished installing my Old School Alpine CDA-7977 into my T/A. May not seem like much of an achievement, but the deck is like an octopus, 3 sets of rca cables, 4V preout box, AI Net cable + additional cabling for the functional gain switch (think bass ****)… it gets tight in there.
Old Jan 31, 2022 | 08:37 AM
  #1609
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
That is a tight area for sure. I put a later model Delco CD radio in my 88 and it bottomed out on an air duct in the back. If it had the little cooling fan it wouldn't have fit at all. That Alpine is good stuff.
Old Jan 31, 2022 | 10:55 AM
  #1610
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Is that an amp on the right, tucked into the dash?
Old Jan 31, 2022 | 01:21 PM
  #1611
It's a line driver, boosts the deck signal up to 8V - Phoenix Gold PLD-1.
I'm running the signal from the deck, to the line driver, to the gain slider, to the subwoofer amp - effectively making the gain switch a "bass ****".
AudioControl has a line driver built into most of their product line, does nothing but good things. I'd look at their products closely if your considering adding an amp to your stock setup.
Old Jan 31, 2022 | 06:59 PM
  #1612
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Ive always liked phoenix gold. They go back a ways. I had one of their amps back 90 something. Wish id never sold it.
Old Jan 31, 2022 | 09:36 PM
  #1613
I bought mine n the mid 90s, upgrading from Pioneer stuff.
still running them today. The MPS-2240 is a factory modded sponsored competition amp - note the passive filters on the line inputs and the additional board that needs all that high preout voltage to make 24W x 2 on my subs (honest!) The MS 275 is garden variety, but still one of the best sounding amps of the era.
Old Jan 31, 2022 | 10:10 PM
  #1614
Swapper's Avatar
ill take one with gray stitching please! lol. looks good. been trying to find someone that sells those.
Old Jan 31, 2022 | 10:28 PM
  #1615
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Got a "1LE" radio delete off ebay. No part number on it and the molding is slightly wonky, I suspect it's a reproduction but it looks pretty good still. Better than an empty hole to drop things into.
Old Feb 24, 2022 | 10:15 PM
  #1616
Car: 1992 RS
Transmission: 4L60
I got my headliner reupholstered with basic fabric and foam, at a local shop in Amarillo that got lots of good reviews.
Old Feb 25, 2022 | 06:16 PM
  #1617
1983LU5TA's Avatar
Car: 1983 LU5 Trans Am, 1967 Chevelle
Engine: LU5, LSx
Transmission: 700R4, 4L60E
Axle/Gears: 3.73, 3.73
It’s a daily driver. I drove it to work.
Old Feb 26, 2022 | 12:21 PM
  #1618
DynoDave43's Avatar
From a Michigander: There's nothing wrong with what you're doing, but that WEATHER is just WRONG for February!
Old Feb 26, 2022 | 12:41 PM
  #1619
mars2878's Avatar
Car: 14 Charger RT rwd dd
Engine: 5.7L Hemi
Transmission: auto
No garage, so I had to dig them out.
Old Feb 26, 2022 | 08:50 PM
  #1620
DynoDave43's Avatar
Old Feb 26, 2022 | 09:06 PM
  #1621
Mike Jendrycka's Avatar
Car: 1987 iroc convertible
Engine: 5.0
Transmission: 5 spd
Axle/Gears: 3:45
Restored tail lights
this will test your patients
Old Feb 26, 2022 | 10:21 PM
  #1622
1983LU5TA's Avatar
Engine: LU5, LSx
Yep, I’m in Phoenix. This baby gets driven 365 days a year 😂
Old Feb 28, 2022 | 11:00 AM
  #1623
Punk's Avatar
Engine: LB9
Taillights look great. Mind if I ask what brand/type of black you used?
Old Feb 28, 2022 | 11:16 AM
  #1624
Punk's Avatar
Engine: LB9
Yesterday I got the IROC running....again. Getting a car sorted out after 10 years of storage is like sorting out a brand new build except all the parts are old and used. Changed the TPI regulator, cleaned and tested the injectors, and a bunch of little stuff, and it's running again.
Also started separating the pad from the tonneau cover. Part of getting the car ready for paint.
Old Mar 1, 2022 | 04:54 AM
  #1625
KR81's Avatar
This one might not be to everyone's taste but after having a pizza delivery kid on a push bike almost run into my open door in a dark street recently I decided to add some courtesy lights to the doors. Went with some repro Pontiac arrow rear running lights for a 67 bird.
Old Mar 1, 2022 | 02:54 PM
  #1626
SbFormula's Avatar
Engine: LT1 6.2L
Axle/Gears: 3.91
Nice!!!!!
I did add some ambiance lights in mine!
Old Mar 1, 2022 | 04:45 PM
  #1627
KR81's Avatar
Originally Posted by SbFormula
Nice!!!!!
Nice work! I wanted to add something in the same spot in the rear arm rests but wasn't sure what to do.
Old Mar 1, 2022 | 07:54 PM
  #1628
Engine: 5.0
Transmission: 5 spd
Axle/Gears: 3:45
SEM hot rod black, cleared with semi gloss SEM clear coat 1k
Old Mar 12, 2022 | 05:48 PM
  #1629
Car: 1992 RS
Transmission: 4L60
I got a little stupid in the snow. A little is all it takes.
Hmmm... This one’s a head-scratcher.
Reeling her in...
I scraped off some more of PO's white primer, broke my 30-year-old plastic headlight-aiming nut, cracked some mounts around the headlight bucket, cracked another split in my chin, cracked my rocker gfx, and bent both fenders.
After two new tires, she still rides fine, but steering seemed a little mushy. My mechanic ended up replacing shocks, struts, tie rods, Pitman & idler. Body & paint will be another year.
Old Apr 8, 2022 | 09:12 AM
  #1630
rearview's Avatar
I took advantage of my lack of an engine and I took out the heater core. I almost got the replacement in, but it got late. Plus the replacement is SLIGHTLY different... anyway, It looks like I am replacing it just in time as it's starting to leak (I hadn't noticed yet) I had to take my dash top off to get to that stupid top bolt. oh well.
Old Apr 9, 2022 | 07:24 PM
  #1631
m0torbreath's Avatar
plugs, wires, maf, ignition control module & coil, productive day
Old Apr 9, 2022 | 07:25 PM
  #1632
if you ever feel stupid, my gas pedal got stuck on my floormat and i ran into a curb. two new tires and I'm still ashamed
Old Apr 9, 2022 | 09:16 PM
  #1633
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Fixed the rear spoiler stud...again!
Old Apr 10, 2022 | 11:44 AM
  #1634
2irocs's Avatar
Car: 1989 Iroc Camaro
Engine: 383 Stroker-Carb Blue Print Engine
Transmission: automatic
Flushed the brake master cylinder and bled brake lines on my 89 Iroc 67000 miles... I doubt the fluid had ever been flushed...Fifty plus years I have worked on my cars this is the first time I have ever flushed a brake master cylinder...Must say the fluid needed to be changed it was dark looking...The brake fluid in the brake master cylinder looks so clear and the brakes work great...the old brake fluid looked water looking...easy job to flush and bleed brakes...would highly recommend flushing the brakes and putting in new fluid...
Old Apr 10, 2022 | 01:13 PM
  #1635
hessm70's Avatar
Engine: 355 TPI w/AFR 195s Dyno Don Headers
Axle/Gears: Borg Warner 9 Bolt, 3.27 gears
Well yesterday I finished up installing a Delphi fuel pump. Just in case anyone wants to know it is super quiet compared to the Airtex pump that as in it previously.
Today, I reinstalled my refurbished radio with aux Jack. Installing the aux jack in the panel on the passenger side.
Old Apr 10, 2022 | 10:02 PM
  #1636
Engine: 5.0
Transmission: 5 spd
Axle/Gears: 3:45
Today I added to the collection, 88 iroc 5 speed G 92 j65 complete rust free and super straight but in pieces. 68 k original miles. Off road since 98! 😊
Dirty but clean???
88 dated eagle gs-c
Old Apr 11, 2022 | 09:56 AM
  #1637
Reddragon88gta's Avatar
Engine: 5.7 L98
Cleaned out the nasty old coolant in the reservoir and cleaned the reservoir, I should have done this before yesterday but the fact the coolant looked good/clean in the radiator and that I probably drained and filled the coolant twice in the past 3 years while doing other maintenance I just overlooked it.
Nasty stuff that was on the bottom of the coolant reservoir.
Cleaned tank and fresh coolant.
Old Apr 15, 2022 | 01:00 AM
  #1638
keeslinger31's Avatar
Car: Camaro RS
Engine: obd2 350 lt1
Reminisced and tinkered, haven't driven it for 8 years
Shes dirty but i'm glad I kept it
Old Apr 15, 2022 | 12:08 PM
  #1639
Carlos89's Avatar
Car: 1986 Trans Am
Just another war story. It's cool man.
Old Apr 15, 2022 | 12:09 PM
  #1640
Carlos89's Avatar
Car: 1986 Trans Am
Water pump pulley started grinding a few days ago. Took care of that with a generic auto parts unit. It works.
Old Apr 16, 2022 | 08:16 PM
  #1641
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Repositioned the brk/gas pedal so they're farther apart. After i accidently overlapped my foot on both backing into a parking spot. I almost slammed a wheel into the curb.
Old Apr 16, 2022 | 10:51 PM
  #1642
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
Tank looks new! How did you get it like that? How bad was it before cleaning?
Old Apr 17, 2022 | 06:24 AM
  #1643
Engine: 5.7 L98
Thanks! So I removed the reservoir and emptied the old gross coolant, then used Dawn dish soap on both the exterior and interior of the reservoir, after letting it set up a few minutes I used one of the those bristle brush baby bottle/coffee pot cleaners to scrub out the inside. After that was done a thorough flush with water and reinstall.
Both inside and out were dirty before, I was stunned how well the Dawn worked. The tank looked almost new on the inside and the outside was much better than before.
Old Apr 17, 2022 | 10:06 AM
  #1644
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
Nice job, Reddragon88gta!
Old Apr 17, 2022 | 11:24 AM
  #1645
gt4373's Avatar
Transmission: 5-Speed Manual
Anyone Seen This Looks To Good To Be True
Old Apr 17, 2022 | 11:36 AM
  #1646
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Thats pretty damn remarkable, thought it was a new tank at first. Sonax is a good cleaner though.
Old Apr 22, 2022 | 08:20 PM
  #1647
Engine: 5.0
Transmission: 5 spd
Axle/Gears: 3:45
Finally got around to starting the paint job😊
Old Apr 23, 2022 | 06:56 PM
  #1648
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Fixed a broken plastic bumper (isolator) on my vert top.
New DIY part.
Old Apr 24, 2022 | 12:25 PM
  #1649
nhgator's Avatar
Car: 1985 T/A
Went for a dust em off cruise with the local muscle car club.
Old May 8, 2022 | 02:24 PM
  #1650
BBCSwap's Avatar
Engine: SBC Dart 400 Holley 750 Carb
Axle/Gears: 28 spline 323 gears
Cut up some furnace duct to help hold up the hood insulation. It was sagging a lot.
