no crank no start
no crank no start
my 1996 f350 7.5 wont crank or start. cant even push start or bridge the solenoid. i checked the starter,clutch switch, fuses,ignition switch, and battery. i also turned the engine so its not froze up. i would appreciate any help at all Ty in advance
Car: 1990 Trans Am
Engine: 5.7 350 HSR afr195 xfi268
Axle/Gears: 3.08 posi
Re: no crank no start
Off topic with ford but similar approach. When ur bridging selenoid or trying to start are you atleast getting a click? Check your voltages at the selenoid and at the starter to make sure your voltage is getting to the starter. Also as a quick test assuming battery has checked out good try bridging positive terminal on battery to small terminal on starter and see if it turns engine over. That would atleast direct your attention to selenoid and/or wires to starter if it cranks and if no crank the starter or power wire to it
